Fokker E.IV 161/16 flown by Lt. Hans Müller
JeroenPeters
Hi Bertl,
Thnx for those! I should have looked at these pics better before venturing in the Taurus engine.
Pure headache material.
1. I glued the cilinders on. Only to discover the engine would not fit the cowling of the WnW kit.
2. I debonded all the cilinders and shortened them 1,5 mm each.
3. Then i saw Aviattic is releasing a beautiful resin scale thickness cowling that will fit the Taurus engine. Duh!
4. After this i somehow managed to glue all the cilinder heads / caps in the wrong way round. This was a pain.
5. And by sawing off the rocker arms from the block I already managed to screw up 2 parts.
This piece of kit really makes me doubt my abilities. You can see an empty strip of aspirine in the background.
Here's where I'm at...
1016392_10152202217777079_721420760_n_zp
Oh, Master Buckle, those are fine parts!
................... hmm .................. you've also cross masks for me?
I have determined some things in my drawer, to make also a deal with you........................  :ph34r: .
Servus
Bertl
I cleaned up all the parts ( as said more than the total of parts that comprise the engine alone!) and started painting the cowling / aluminum parts. Swirls!!
All this will be covered up and partly brought back with the hairspray technique.
2E041A4E-D9C0-48C7-8D6E-5091AC9BBDF5_zps
