HK Models B-25J-1 "Old Ironsides III" (Diorama Finished)
On with the first part of texturizing and weathering the NMF...
First step, sanding back rivets and cleaning up the surface, when done, fading it with Alclad white/polished aluminium...
Next step - Salt mask, when dry, alclad aluminium of different shades...
Salt rinsed off and a couple of panels have been picked out and 'dusted' with Alclad dark aluminium...
The subtle patina and texture of the NMF..
very nice
working on my own HK B25 now
1) do you (? & others if anyone wants to chime in) mix & airbrush the Mr Surfacer prep coat or do you spray it straight from the rattle can?
2) did you seal/protect the alclad finish with a clear coat before applying the huge insignia masks? I'm really worried about tearing up the underlying paint when I remove them...
Thanks in advance
Doug
SoCal
The work continues on the 'Old Ironsides III' diorama...
Diorama base: 60 x 60 cm board + 10mm polystyrol...
Embankments from the debris clearing the stands on two of the edges...
Everything is covered with a thin layer of modelling clay DAS/FIMO.
To create the surface, fine 'bird sand' and cat litter is used, glued down with thinned white glue.
Wheels from different vehicles and aircraft tyres is used to make tracks + footprints, a lot of footprints!
Dirt road in the corner...
Thanks Cees, fortunately the house pet is a Cairn Terrier, so I think I'm safe there?
And yes I can finally see the light at the end of the tunnel on this project, and It has been quite the ordeal.
The learning curve has been steep, with a lot of things I haven't done before, a lot of trial and error....
But when I look back half a year, this kit was lingering on the 'shelf of Doom' only to be saved by this contest,
and the inspiration of the work of all you guys!!
Kent
Canopy and nose glass finished... Nose hatch removed + opening of the cockpit side windows...
Wasn't impressed with the Eduard escape hatch, so a scratchbuild one to resemble the real thing a bit closer...
