5 hours ago, Peterpools said:
Kai
Nice work on cleaning up the canopy fit and the scribing looks perfect.
Keep ‘em comin
Thank you Peter!
Meanwhile I‘ve also finished the riveting. Moving close to the painting...
Kai
Link to post
Yesterday I added all the missing rivets to the airframe. Took some time but now it’s finished. Here are some sample pictures:
Then I moved over to the guns. The representation Italeri created is more than poor.
Since the caliber of the gun is 30mm I used 0,9mm cannula to replicate them. I used reference fotos from the Duke Hawkins Book. The damping-rings are not the same for the C and DS but the arrangement is the same:
The damping-rings (although prominent on the real plane nothing provided by Italeri) came from the Eduard Exterior Brass Set and were really fiddly to bend and glue:
But the result was acceptable for me.
The last thing I did was to add the pitot tube to the nose. It has to be attached already at this stage because it’s partly painted.
I used the Master pitot which needed some rework to make it fit  perfectly.:
That’s all for today.
This is how my Mirage looks like now:
I now will go on with the landing-gear and the preparation of the plane for priming.
Link to post
10 hours ago, GusMac said:
Looks great Kai. What's surprised me is how long this thing is!
Thanks Gus,
If you mean the pitot: I think it protrudes so much because it should be in totally undisturbed airflow in front of the plane (same as with the 104). But could also have another reason...
Link to post
Your exterior looks great!  I really like the guns and dampeners.  Good luck with not knocking off that pitot tube.
  • Haha 2
Link to post
Thank you Gaz!
The pitot tube is metal. You can pick up and hold the plane on it. Hope that I won’t knock it off. ;)
Link to post
Hi Kai,
Looking better every day, love the dampening rings on he guns, these kind of details will make the model stand out for sure, good choice on the pitot tube, they really make nice parts at Master's
Looking forward to the next build stage,
Frank
Link to post
1 hour ago, Trigger said:
Hi Kai,
Frank
Thank you Frank,
Master really makes beautiful accessories. I use them as often as possible for my kits. Especially the pitot tubes make life for them much safer like on the F-104 or MiG 21 or EE Lightning.
Link to post
Yesterday evening I took care once again of the cannon dampers. A friend of mine told me that the web between the damping rings wasn’t present on the real aircraft. So I carefully removed it:
Then I moved over to the landing gear.
The front landing gear only has the hydraulic lines for the nosewheel-steering. The landing-lights aren’t present at Israeli Mirages.
The hydraulic cylinder of the nosewheel damper was painted with my 1 mm Molotow Chrome pencil.
Then I brushpainted it with Tamiya XF-16 flat aluminum. Detail painting and slight weathering will follow:
Next was to paint the hydraulic dampers on the main wheel legs, because after installation of the scissors on the legs you can’t paint them anymore:
Again Molowtow pencils (1 and 2 mm) were used. This has to dry overnight before I can continue with the detailing.
Last thing I did was the assembly of the subsonic tanks.
What do you think about the fit? Correct: also here rework needed!
Since this was the last assembly of the kit the result is: No assembly of the whole kit without any rework!! I never had this up to now in my long modeler life...
Next will be to finish detailing of the main wheel legs and detail painting of the assemblies.
Link to post
Kai,
    The improved LG look great!  I'm not surprised about the fuel tank. The kit is a lemon.
Link to post
Kai
Holy Cow - Awesome work. The dampening rings look great as well as the gear - not to mention finishing the rivets, nose gear and detail work.
Can't wait to see the Mirage after her priming in the paint booth.
Keep 'em coming
Link to post
1 hour ago, GazzaS said:
Kai,
Thanks Gaz, This kit really is a lemon! Very good description...
Link to post
33 minutes ago, Peterpools said:
Kai
Keep 'em coming
Thank you Peter,
when I have finished the landing gear I will start the painting process.
Kai
Link to post
This evening I added two prominent filler caps to the upper fuselage. Italeri simply left them out:
Then I painted the flexible hydraulic hoses of the front landing gear:
Not that big...It‘s now ready for weathering.
Finally I prepainted the main landing gear legs and added the scissors. The casting quality of them was really bad:
fresh from the sprue...
reworked ...
Finally I scratched 2 rings which I glued to the legs and which are used to guide hydraulic lines to the brakes:
Next step will be to add the hydraulic lines to them.
Link to post
Nice details, Kai.  A dark wash will set everything into relief.
I remember being under the Wheel Well of an F4 Phantom.  As a modeller, we see these as small parts.  But IRL...  they are quite massively thick.
Link to post
Kai
Terrific work on the gear. Just have to hand it to the crew at Italeri for not missing any opportunities that require cleaning up their charming work.
Keep ‘em comin
Link to post
Thanks Gaz. That’s one of the next things to follow!
I know what you mean. It‘s really impressive when you are standing in the last-chance-area of an airfield and a huge Phantom is rolling towards you...
Link to post
7 hours ago, harv said:
Good God buddy, your nailing this !!.....harv:popcorn:
Thank you Harv!
BTW:
What about your F-16 and the japanese  fighter ?  Did I miss some of your updates?
Link to post
4 hours ago, Peterpools said:
Kai
Keep ‘em comin
Thank you Peter.
This is a good idea. Maybe I can send a photostory to Italeri when I‘ve finished the build...
  • Haha 2
Link to post
Kai
Great idea. Mine is still in the box, never opened, plus I have the IIIC upgrades and most likely will remain that way. After following all your incredible work, I quickly came to the conclusion, it's way too much work for me to tackle at this stage of the game
Link to post
Yesterday evening I detailed the main landing-gear legs with hydraulic pipes.
These were my reference pics:
C6E431B9-5B9A-4C7C-BDB3-1CF92B695D40.thumb.jpeg.2f87289145090aea46f9b33fe828f6db.jpeg9EF2D3E0-70AF-40E7-93A9-A0B0B01BC008.thumb.jpeg.c9b79dfd6f3fa8fc17976cc22ee6769b.jpeg
and this is how the legs of the model look like:
I didn’t add any electrical wires since they would have been too small.
Now their painting can be finished and then weathered.
Link to post
Great looking gear!  I have to admit...  getting those brake lines to stick in place...  drives me mad.
Link to post
  Only 75 emoji are allowed.
