Crane Jane and Maz Man
Thanks for the great comments everyone, and for watching the build.
I got a few more things finished inside the frame, but I'm seriously procrastinating with the suspension work.
I did manage to get parts cut for outside of the rail.  At this point tho, it is just a pile of parts.......
I also finished building the main Transfer Case..........
I managed to also build the connecting Drive Shafts and get everything installed.
  This was a relatively easy process after painting, and while I was starting the weathering........
Well, that's just not right.
I was looking at these photos with the wet weathering and was wondering if anyone else would notice the HUGE MISTAKE!  The drive shaft at the bottom of the photo is installed backwards and the Transfer Case is also installed sdrawkcab!!!
I use superglue by the gallons to build my models, so prying these off the frame was a bit fiddly, but it all worked out........
'at's betta.
After that close call, It was off to built the air tanks and start with the plumbing for the brake system.
The build is at this point tonight.
I'll be back with, maybe some suspension done.  Later All.
Alright Then,
 I managed to get some work done on the suspension system, in between boxing the house to move.
Not a lot of photos today, but some work done on all the crazy parts for this system.  The first was the anchors for the suspension.  These hold everything into place.
These are attached to the frame around the opening that the drive shaft passes through.
Everything looks to line up great.  On to the next step........
This all line up just right, so on to the suspension away from the frame.........
You can see the "A" arm to the right.  I have 16 of these to build.  For this build I need 32 copies of everything for both sides.
I still have packing to do, so next report will probably be small also, but it's getting worked on.
Until next time all...........
Hey All,
  I have managed to get a little more done on the build.  I have painted the suspension system anchors, and have them bolted to the side of the frame.  Here you can see that all these anchor items still line up good enough.
I even succeeded in getting the torsion bars to avoid blocking the axel shaft passthroughs.  I feel better about everything matching now and the axel shafts should match the A arms and join at the hubs.
I'd rather be boxing for a move than building all these A arm components, but I got through building these in just a week.
32 of these.  16, top and bottom each side.  I now have to find some material to build the hubs to the wheel connections out of.
I'm in for a time with the wheel hubs.  The four back hubs are all the same, just four copies.  The four front hubs are all different.  each of the hubs has a different steering component attached, so the hub is mirrored front to back and then mirrored to each side.  Fun times.
That's it for this week.  I'll keep building between packing.  Thanks All.
Hey Guys,
A really busy week here.  I had to go to the new house to work a bit, the inspector wanted me to fix a few things.  A two hour drive there and two hours back.  About 115 km/70 miles or so.  Also, in between boxes, I got some good progress made with the build.
I did get the "A" arms built, but grudgingly.  The suspension system is so boring to work on with all the repeat patterns to deal with.  I also have some "pain in the butt" geometry for the back wheel hubs that I can't seem to get a grip on just yet.  More on that later.
To break up the boredom, I started working more on the drive train.  The transmission and drive lines did the job.
We control the transmission........
This, painted and installed........
The transmission has a ridiculous amount of plumbing to install, when attached to the engine.
I also built a large body support for the upper body panels.  Altho not installed, this what it looks like.....
It lives about here........
The red lines with the blue fittings are not weathered in just yet, so they stand out a bit for now.
As of this evening I have started with the Engine build.  This is the far aft of the engine that connects to the transmission via another drive shaft..
That's it for now.  I have no clue what this next week will bring for build time, or moving time.
Until next week All.............
Hey Guys,
 A short report tonight.  I have gotten some more work done on the build.  The postings are going to start stretching out here for a while.  My rental is stacked with boxes and the furniture is bare.  We are boxed up for the move and the paperwork should close in the next week or so.
Meanwhile, at the scale of this build, the engine is large.  I had a bit of a time finding something to build the engine block out of.  I found a thick card tube to use as the main build element, and attached everything to it.
Turning a round tube into an engine.......
I had another drive line to build.  Believe it or don't, I still have two more to build. This is #6, out of 8.
I'm adding the details as I proceeded.............
As of tonight I have the basic block ready for details..........
I should get more hours to build with the house boxed up.  But still slow for now.
Until next time, sometime..............
Hey Guys,
A small report this fine evening.
I have been working on the suspension system "A" arms, doing the final sizing for install.  Everything still lines up good, and, once again, I have multiples to finish for install.
I also have the engine block painted and ready for install.
Once the engine was painted, I now have to build and install all the separate items that are attached to the block.
I used some sprues to build the water intake manifolds.....
I also built a distributor, and the exhaust manifolds.
I don't always get to work on this for very long with all that's happening, but I manage to get a little done.
Until next time.....Thanks Guys.
Hey All,
A little more work done on this build before the move.
I am working all over on the build at the moment. Several things going on at once.  Plus some corrections.
 I erroneously reported on a couple of facts that are not true.  #1, I reported last posting that the inside piping from the heads were water intake manifolds.  Not true, these are in fact exhaust manifolds.  This is a twelve cylinder engine.  the exhaust is vented on each side of the heads and have three exhaust ports on each side.
#2, I rote that I had built 6 of 8 drive shafts from the engine.  This is also not true.  I found two more drive shafts from the engine, making ten different drive shafts in total from the engine.  BUT, that's not all, and this is a big but, like the lady in the third row of the church quire be havin'.  I have eight more drive shafts to build for the connections between the differentials and the wheel hubs.  So I have ten more drive shafts in total to still build. errr.
I worked some more on the suspension system, getting things painted and installed.  Once I had everything cleaned for install, the assembly went smoothly enough.
I also worked on the Valve covers..........
these are painted and installed..........
All to get grimy, later on.
I also started the large Radiator, that sits right up front on this build........
Fan shrouds.......
I'm actually building what I think I can finish while I have the build desk still available.
I might get to make one more posting before it all hits the fan for me.  Thanks All.
Until next time..........
Thanks Guys for the best wishes.
Hey All,
 The move went well and I am now on the other side.  I have established a temporary build station, and have noted the travel damage.
The only thing that got damaged was the tail hook.
Easily repaired.
The temporary setup.........
And the new model stash room.  Just a closet.......
This makes my stash look really small.  I'll have to work on that.
I'll be back in between un-boxing the house.
Thanks all for the wait.
Slowly starting again while getting the house in order.
I have worked only a little this week or so.   I did do the fuel injector lines on the engine....
I also finally started with the wheel hubs and steering,
this was a tricky piece to get a grip on the geometry, and I may have to trim this a bit to fit properly.
This lives about here or so...........
The house has a million things to work on, so only an hour or so of work here, in the evenings for now.
I believe that this steering arm is the hardest thing to build for the rest of the suspension system. We'll see.  I have four of these to build.  which means that I'll cast this for the set.
Gettin' back into the build again.  Thanks All.
  Only 75 emoji are allowed.
 Share
