Hobbycraft F6A D-Day - Ready for inspection!
That was a bad picture, this one is better.
I was torn if I should have used my last set of Resin2detail radios, as they are no longer made. I decided to save them for either the B-17 or B-24 build. I added some scratch detail to the kit radios, pretty basic, but as they are buried below the camera, it would be hard to see them later. I also robbed the battery from my Trumpeter P-51B. It’s basic, but not terrible. I also made a fluid reservoir (not sure for what), and finally added lead wire to all the cockpit boxes, not visible here.
I have been saying that for a long time, everything is pretty accurate, just lacking in definition. This is the second hobbycraft mustang I built, didn’t need a resin cockpit for either. I hope sombody buys he molds and re-issues the kits.
I started to close up the fuselage today, however, I discovered some fit issues. So back to some trimming. The fit issues were with the rear portions behind the armor plate. I had to trim the receiver board and camera mount, luckily, the cuts can’t be seen. I am also not very pleased with the self adhesive Edward PE, a couple pieces keep popping off. I’m going to have to give them a few dabs of CA.
This was also the first time I used Fine Molds seat belts. I like them, they can be folded and painted, real quick. I started to built Edwards 97 part PE seatbelts, but i just did not have the patience for them, and remembered I had these. I like them.
I did manage to get everything to fit, and I started to fit the wings. A little bit of sanding off burrs, and the wing gaps were amazingly tight. Things are rocking along now!
