1/32 Heinkel He 111 detail sets
CMK
Catalogue # check article for codes
Available from Special Hobby. Links in article.
We recently looked at the 1/32 CMK He 111 Interior set, which provides a whole new replacement cockpit for Revell’s large and rather nice kit of this iconic German medium bomber. That set merited a standalone article due to its complexity, as you can see. However, in this article, I will take a look at the other sets available for this kit, again from CMK.
Set # 5068,Heinkel He 111P - Wing fuel tanks, 418 Kč (approx. £15)
Purchase link
This set is packed into one of CMK’s larger blister packs due to the quantity of resin within. I actually couldn’t get it all to fit back in once I’d done the photography for this review. Designed to give the modeller an option to display the two inboard fuel tanks, this set requires some radical butchery of the main lower wing panels, so be prepared. A significant proportion of the plastic will need to be removed between the main gear bay opening and the fuselage.
You are supplied with EIGHTEEN pieces of light grey resin, all flawlessly cast, although one fuel bay wing skin panel will need the hot water treatment to correct its shape. The premise of this set is quite simple. Each bay needs to be constructed from a ceiling and four sidewall pieces. All of these are suitably detailed within, bearing in mind that they will be filled with the tanks (2 per bay). Those tanks are nicely detailed, with securing straps and fuel filler points, plus the ribbing that could be seen on the rubber skinning of the tanks.
Externally, the main wing bay panel is devoid of detail, as per the kit, but internally has some constructional elements cast into it.
Instructions are clear enough with simple line drawings telling you all that you need to know. Details are provided for painting too, with codes given for Humbrol paints.
Set # 5069, Heinkel He 111P Fuel filler necks and life raft, 247 Kč (approx. £8.50)
Purchase link
I must say that this is an unusual concoction for a detail set with a life raft compartment being sold with fuel filling points! Now, as the previous set shows you the wing fuel tanks from below, this set provides the tank fuelling points that exist in the inboard area of the upper wing panels. Instead of removing whole swathes of plastic though, you simply need to drill out the filling points on Revell’s moulded plastic. Underneath these points you will fit a resin box that will have a fuel filler point fastened to. Parts are of course supplied for the fuel filler plates that you drilled out previously. No real clean-up needs to be done on the resin boxes, but the filler ports and access plates are cast onto a block and will need removing and some tidying before you can use them.
As for the life raft, this is a very simple mod indeed. After cutting away the relevant plastic on the spine of the He 111 kit, you will secure a compartment within this area, lipped so that it will recess into your newly-cut opening. When the fuse is closed and the compartment painted, a resin life raft can then be dropped into position, all folded with the relevant details such as gas canister and pull/inflation cord. Lastly, a panel is supplied which would cover this area. Casting is again excellent, and this set is packaged into one of the smaller CMK blister packs. Instructions are clear and easy to follow, with suitable Humbrol paint references.
Set # 5070, Heinkel He 111P Tail undercarriage strut and bay set, 247 Kč (approx. £8.50)
Purchase link
If you’re going to super-detail your He 111, you may as well do the job properly. Presented in another blister pack, this set contains just five pieces, cast in light grey resin. Some casting block removal will of course be needed. Once done, this is a very simple set to install.
Port and starboard tail wheel well walls are cast various constructional element details, such as longeron and stringers, plus a little plumbing too. Not too much, so you can add more if you feel the need, but this should be good enough for most modellers in the detail stakes. Once these are fitted, painted and the fuselage closed up, the resin wheel form is then fitted to the strut (I suggest pinning this too), and then resin pins are used to fit the tail wheel itself, plus the strut into the bay. As the locating point is quite high in the fuse, this could be a little awkward. I would also suggest you replace the resin pins for this job with some steel pins or rigid wire.
The instructions look simple enough to follow, but the proof of the pudding is always in the eating. Looks a great little set, providing all fits well.
Set # Q32159, Heinkel He 111H/P Instrument panels, 134 Kč (approx. £4.60)
Purchase link
Out last set is packaged into a standard sleeve with a cardboard backing. If you don’t wish to fit the entire cockpit set, then this simple upgrade could be for you. This set is designed to replace the Revell instrument panel with something far more presentable. Firstly, a resin panel is supplied, and this simply has rear instrument detail. You will need to add wiring etc. to this yourself. Onto the front of this fits a two-part photo-etch instrument panel, produced by Eduard and printed in full colour. PE quality is excellent, as we’ve come to expect from Eduard.
Two other resin parts are included and cast onto a single block. These are for the large central console that fastens into the upper canopy area, and for a small side console. Details are very nice and I think just a little accompanying wire will seal the deal.
Again, the instructions are simple but do the job effectively.
Conclusion
If you want to super-detail your He 111 kit, then whilst Eduard will provide some really nice sets, such as the bomb bay etc., if you want to add resin to enhance your work, then these really are the only sets in town that will give you what you need. Thankfully though, CMK’s work is excellent and straightforward to fit and the price is more than acceptable. All we really need now is for Revell to start moulding their kit again and perhaps we can see more of these sets used on the club and competition stalls.
Highly recommended
My sincere thanks to Special Hobby for the review samples seen here. To purchase directly, click the links in the article.
