ICM
1:48
Luftwaffe Airfield Equipament
Price Tag: €17,80
Catalogue number 48409
ICM is unstoppable.
Now a new important 1:48 for Aircraft modeler to adventure themselves to the diorama world.
As you can see in the boxart, inside the box, some 50kg bomb crane, 250kg bomb crane, jerry can, fuel barrel, barrel for lubricants, compressed air cylinder, toolbox and even an airbrush.
A LWC 500-IX (finally one in plastic in 1:48) and fabulous field tripod crane. The parts are very detailed even the chain in plastic is well made for 1:48 but if there is anything that is worth upgraded is the chain and it’s an easy upgraded to make.
If these wasn’t enough, ICM gives you even more, a road barrier, a watchman`s booth and a small stepladder.
To complete this beautifull airfield set, a decal sheet for the crates, barrier and booth.
All these plus a full ordnance set.
All parts have no flash at all, and the surface detail is very very good as the actual ICM standards.
The small parts like a tiny 1:48 airbush are just perfect and very well mold with no flash and very little cleaning or almost none.
The connection points sprues in perfect places to make easy the cut from the sprues.
BUT, This set has much more to offer than ordnance. We already review part of this set when we took a look on the Luftwaffe ordnance so everything is here too inclusive a large decal sheets for the bombs.
Just check here.
The instructions are very clear and easy to understand as usual. Th color charts is only with ICM paints.
Conclusion
Wow! What a set! A Perfect invitation at low cost to all aircraft modeler to make a diorama!! No excuses anymore!
Kudos ICM!
VERY HIGHLY RECOMMEND.
Our sincere thanks to ICM for making this fantastic set.
To get one just click here
       Francisco Guedes
www.largescalemodeller.com
