richdlc Posted August 20, 2013 Author Posted August 20, 2013 *update 14th August 2013* Hi guys! Well, that special moment has come where I realized there is little more I can add to the Fort. So as of now, I am calling it 99% done! There's a couple of aerials I can add, plus I need to detail the large radio room roof window (removable on the real thing so I'll have it removed & lying on the ground). So I'm going to post up some pics - I'd really appreciate it if you find any glaring errors to let me know - now is the time to fix them! I've got just under 3 months until the Nationals and next up will be the diorama - which means buying / creating / painting some figures and doing some groundwork. Until the diorama is complete I can't call the Fortress 'complete' really as everything is interconnected... so once I really have finished I'll create a 'ready for inspection' thread - with the moderators' permission of course as strictly speaking this isn't just an LSP build. I will be updating the 'non-LSP works' thread about the wrecker / trailer with some diorama build pics etc. in the coming weeks.. OK - to business. One of the very few parts I cannibalized from the HK Models test shot I had was the tail wheel assembly - HK provides this with a bulged tyre, so, I simply built up the bulged bit again with plastic card & blended it in: Here it is attached - dust & dirt added from MiG pigments: I also needed to make the rear crew access door, which I did from a piece of pewter & some heat-formed plastic card - here it is prior to painting & window installation: And in place: My reference pics showed the real Fort fuselages resting on a tonne of wooden dunnage & other crap on the back of the trailer - I replicated this effect with some chopped up balsa (bulk buy from the Model Zone liquidation sale!) - stained with oils & drybrushed etc it makes a nice cradle for the fuselage to sit on: The fuselage was attached to the trailer with a suitable screw - I drilled right through the bottom of the trailer into the bomb bay - as this area is hidden & un-detailed it was no biggie: Waist gun windows were made with clear thermaform which was bent to shape after immersion in boiling water. It took a few attempts but I was (kind of) happy with the results. I had a full set of transparencies - two actually - from the HK kit, but unfortunately, as discussed in earlier posts, my build and the kit don't match up in terms of dimensions... It looks horribly distorted & dusty here (damned macro images!) but in real life if about as clear as I can get it. The waist guns were mounted at the same time. I attached those with normal plastic cement, and the transparencies with Gator's Grip Acrylic glue (good stuff!): Before the fuselage was attached to the trailer, I of course has to finish the painting & weathering. I wasn't happy with the decals, so I hand painted everything except the pin-up girl. Here's the name & mission markings - the name was painted using the custom masks, the mission markings and all gun-station names were painted freehand. And here's the pin-up girl. I was happy with the decal for this one, and in the end got it looking nice! It was semi-transparent & shows up the weathering of the aircraft's skin nicely for a realistic effect. I sealed it in (and at the same time sprayed the entire front section) with Testor's Dullcote for a nice, flat finish. Final details like these formation lights and the antenna were added: That final skin panel was attached: and the top turret finally fixed in place: The problem of the vac kit's crappy astrodome was fixed when I found out that this was sometimes retrofitted in the field with a flat piece of perspex (also note in front of that another piece salvaged from the HK kit, namely the AN/ARR-1 antenna) I also attached one of the final pieces, the Norden bombsight. I scratched the hot air defrosting pipe system as well, which is always missing from restored aircraft (and the HK kit incidentally) - the nose transparency is from the vac kit - I wasn't at all happy with its clarity, and even with a couple of coats of Klear it doesn't loook great...oh well. At least it fits! I had a spare HK one which I smashed up and tried to replicate the same effect - unfortunately it's extremely thick (and also has the correct profile and shape - something I'm afraid mine doesn't) so it doesn't really fit onto my kit's nose... This pic also shows the chin turret attached. I made the flash eliminators for the guns from rolled up bits of pewter. On the real aircraft, these were added as early Fort crews found the continued flash & shock from firing those big guns could crack the nose glass. I also kind of solved a problem I had with the destroyed tail cone - if you look inside there's a big void where no doubt I could have added some more detail. I created a bunch of cabling to hang down from the ceiling and made sure the twisted metal hid a lot of what's visible. Nevertheless, if you look inside in strong enough light I think you can see a pleasing enough representation of what's really there...in any case I'm happy with it: Right - enough teasing! Here's some walkaround pics, taken in natural light... That's about it for now... as I say I will be updating the trailer/truck build thread with progress shots from the diorama. Oh yes - I will be securing the Fort to the trailer with some chains / tie downs / ratchets or what have you - can't just have it sitting there! Until next time, thanks for looking Rich
