ART SCALE KIT
Art Scale Kit
Masks
Several Masks
1:24 Hawker Typhoon Mk IB (Airfix)
1:32
Spitfire Mk. IXc (Revell)
 P-51 D Mustang (Tamiya)
1:35
Focke Wulf Fw-190 A6 (Border Model)
1:48
F-86 (Revell
PV-1 Ventura (Revell)
Hawker Hurricane Mk.II
 (Arma Hobby)
F4U-1D Corsair (Academy)
A-10C (Academy)
F-14D Tomcat (AMK)
AH-1QS (Special Hobby)
(HK MODELS kit)
Available at ASK store, here
The aftermarket that I never, ever, miss in all my work: canopy mask.
For one main reason: time (and personally, I hate masking canopies)
With  a much less amount of time you get a very good result that you also can get in the tradicional way, but with lots of time “wasted”…
And there`s is a new player in town… and climb right on the top of the masking canopies world: ASK Productions canopy mask.
I already use these masks in the 1:48 B-25J and the 1:32 A-20G.
So all the masks come in a plastic bag like all other mask set from other brands.
The mask itself is made from a tape very similar to kabuki tape, only a bit darker.
The inside instructions are very clear and every mask it has it`s on number. Great touch to make your live even easier.
You can get two types: one side mask and double-face mask.
This so you can mask inside to make more realistic your build. It`s practically impossible to paint inside without this.
 The mask is easy remove from the sheet with a fine tweezer
The glue on the tape is very good and it is resistant so you can glue and unglue form the clear part to get the perfect alignment without worries of losing the tape glue.
The numbers are simply perfect! A great add to find that small mask in the full yellow sheet.
Having already worked with these masks, you can get all the masking ray in a few minutes. It`s perfect.
CONCLUSION:
I love these masks set. It`s a must have in all my builds.
It’s not a laser cut as ASK use a very high quality cutter that use different cutting speed and a daily changing knifes.
It’s a perfect product with perfect tape glue, perfect tape, with super clear instructions with the numbers of the mask that makes the job super easy and super fast.
Very VERY Highly recommended
Fran
Our thanks to ASK – Art Scale Kit for the review samples.
You can get this set and all mask set at Art Scale Kit webshop
