Administrators Fran Posted May 17, 2024 Administrators Posted May 17, 2024 ICM 1:48 WWII German Aircraft Armament (Catalogue number: 48408) Price Tag: 15,80€ ICM is a quite prolific model manufacture, releasing AFV, Airplane and figures. And now also accessories in 1:48 and a very important one: ordnance. The name “armament” is not truly the best one to get a set of bombs… Armament is more direct to defensive guns or cannons (as attacking guns). These are bombs so I think the more accurate term would be: WWII German Aircraft ordnance. Ordnance is the term often used when describing the payload of air-to-ground In this set, you get 6 types of bombs (range of bombs from 50 to 2500 kg) and two torpedos with a trailer each.. All parts have no flash at all, and the surface detail is quite good so you get several options to use in more than one or two dioramas or vignette alongside your airplane. A quite large decals sheet is given with bomb markings! The instructions are very clear and easy to folow. The cloor indication is good with only ICM range color given. Conclusion So, everything you need to get some really looking WWII German bombs is here. Either to put directly on an aircraft or side by side to an aircraft, it´s always a a bonus to your model as these have crispy surface detail and several range of bombs. Very usefull set to all aircraft modeller. Great Work ICM! Keep Then coming! HIGHLY RECOMMEND. Our sincere thanks to ICM for making this fantastic figure set. Francisco Guedes www.largescalemodeller.com
