The add-ons and details for the Mirage IIIE have been a success. So we have expanded the collection to new items. At the beginning of February, 2 variants of the MATRA R530 missile will be ready for sale with the ventral launcher rail that is compatible with the entire Mirage III family.
One with the launcher's fairings removed so that the pod can be attached to the fuselage by the ground crew. The MATRA R530 is lying in its installation cart. The cart can be mounted with or without the upper lock which is disassembled at the moment just before the missile is assembled.
You can choose between the infrared version seen in the illustration, or the radar version with opaque cone and slightly longer. The work includes a well-worked finished details and riveting, and decals for all the pieces.
The other version consists of the missile already installed and with the pod’s aerodynamic fairings already closed. Again, you can choose between the radar or infrared version.
Finally, a ground power generator trailer valid as a companion of aircrafts of the era between the 60s and 90s.
It can be opened to let the modeler to mount batteries and switch to have this problem solved over the diorama as happens in the reality. Supplying power for leds for its own lighting and for the aircraft. Consisting of backlighting for the control panel and corner lights for lighting the load jobs. But the main objective of the model is to supply low voltage electricity to the aircraft for its own lighting with leds, such as position and cockpit lights.
For this, you can connect real electric cables from the batteries in this model to the aircraft visible on the runway without the need to make holes in the landing gear of the aircraft that weaken its support or complicated lattices under the diorama to reach a front switch. The cables are simply visible on the runway as in any power charging process of a real aircraft.
For the Mirage IIIE, these cables can enter into the aircraft if you have purchased our detailed exterior of the Mirage IIIE, which already includes the ventral opened panel for the power load.
As historical reference, this generator model was used in bases with Mirage IIIE and later with Mirage F1.
We are still working on other models as ever, using the best printers in the world for this type of works. The laser SLA. Like the J-79 GE3 engine for the F-104 A which was months late due to special orders.
Many modelers ask us if we will release these and other models in 1/48. The answer is yes. But please, please be patient. Contrary to what many people think, a design does not fit all scales. It must be fine-tuned in many details. Therefore it is important to finish very well the designs in 1/32 before making variations for 1/48.
All the story and previous models here: https://www.tecnikit.com/catalog/index. ... anguage=en
Thanks to all for the attention.
Nice additions to your range 👍
Ànd your J-58 is a work of art. Now, we just need a SR-71 to go around it.
Thank you very much Hubert !
Yes, it was a monumental job. And yes, I’ve been rounding the idea on the SR-71 for 2 years. But it would be a very time-consuming adventure. I keep thinking about it.
