It is coming up to time on my Spitfire XVI build when I am considering how to mount the excellent barrels to my Spitfire. My mark 1 eyeball and logic suggests the outer circumference of the kit part is the same as the circumference of the turned metal. Therefore merely thinning said plastic to "slide" the barrels in would not work. I am considering removing the plastic by saw back to the front curved insert and then thinning the sides of plastic to create an oval, leaving hopefully a correctly sized hole. The obvious problem if I screw the pooch is that I will not have an insert to mount any cannon.
For those of you out there that have faced this first world problem...how did you resolve it?
Pictures speak a thousand words:
A544237C-4BDF-4F08-BE63-DE669913DAD9_zps
88224EBA-C2AA-4C3C-844A-2776094269C6_zps
347BCD1C-2C04-40A7-A4B2-58CB11EC36AA_zps
B4C3D3E7-42FA-4ADF-ADEC-083CE423DD03_zps
Regards,
Welcome to my issue that I had on my build...
The only ways I saw was to remove the plastic and try fill everything in to make it smooth...
Or
The get the barrels turned and remove the brass so it just slots in..
Or
I thought that may be the case. I have sent Master a strongly worded email :)
Thanks Dave
Yeah I didn't understand why they haven't made a set to just drop in like the other set of cannons for the earlier mk's
You would think so but apparently (or so I have been led to believe) they were made for either the Tamiya or PCM kit. However to have tooled them the same as the previous set for the Tamiya C wing, would have meant they were too short for use on the PCM kit.Still thinking on it.....
Regards,
I have a info that MASTER allready designed E wing sets for Tamiya Spitfires - but they will be ready for sale in the second half of the year :(
That would be right! Ah well, I have a friend with a lathe and some skill. I will be talking more with him this weekend and handing over the parts to see if he can turn them approriately!
Curse you Master!!!!
Regards,
