Just started on this last night. I had originally intended to do this one "buttoned up", but the cannon isn't half bad and with a bit of plumbing and wiring I think it might look impressive to leave the cannon bay open. Test fitting of the kit implies excellent fit.
1471313753240-48257260_zpsoc3ii7vc.jpg[/url]
Well you can Jeroen.
If you have got the old 1/32 Revell one and only use the nose part for the gun with a barrel from Schatton and put it on a Trumpeter kit, than it is possible.
efrick, lovely start.
Cheers,
Arnold
  • 4 weeks later...
Jeroen, I also just found out that there is a conversion set from Schatton Modelbau for this in 1/32 for the Trumpeter kit.
Just google Schatton an you will find their website.
Cheers,
