rverissimo Posted January 3, 2017 Posted January 3, 2017 Hello! I would like to present my latest model. Recovered from the dark corners of my workbench, this model was started a couple of years ago and as i lost the decal sheet, left it on the basis "I will resume it some day..." The paint was completed removed using several grade sandpaper and polishing files and then a complete repaint using Gunze acrylics replicating the colour scheme for the F-16A from Portuguese Airforce (PoAF). On the same way, identification marks and serial numbers were used from a Santa Cruz 1:72 decal sheet for PoAf F-16A. With the paint and decal job completed, i started with the weathering process, using Oils to replicate some patches on the fuselage panels. I wanted to test a greasy and dirt look on the gun hatches on the airplane's nose. As this is a 1:72 bird i need to refrain myself, as i wanted a very "controlled" and weathered area. This is the result. It has several error that i didn't bother to correct, but above all, it is finished and i've learned some new tricks! Thanks for watching! best regards!
Carvair Posted January 3, 2017 Posted January 3, 2017 I like it a lot, it looks very convincing.. Jan
