Concrete Telegraph Poles
MiniArt 1:35
Catalogue n.º 35563
(Buildings and accessories series)
Price tag: 13,50€ (available in MBK – Modellbau-Koenig)
This set is a quite useful one in several sceneries since WWI and modern conflict so it’s a quite useful set that I was quite happy to see it release by the same usual suspect: MiniArt.
This set has a quite strange looking box… It’s a very long and sturdy box.
The inside is quite simple with 4 identical sprues containing the poles and fixtures, and two transparent ones containing the lamp lenses and light bulbs.
These clear parts are quite a really nice touch of realism, one thing that we expect from MiniArt. Kundos.
These poles are quite big -  20 cm long each. So in 1:1, its represents a pole of 7 metres. Sounds accurate to me.
The injection mold is very well done with very fine details.
The fixtures are very thin and fragile so extra care must be taken to remove then.
The only low I can point to this fantastic set is the fact that the poles do not have grainy surface of poured concrete. However its not hard to replicate that grainy surface if you want to.
The instructions are in the back of the box and the construction is quite straightforward and easy.
Conclusion
Another winner from MiniArt.
An original subject, with tons of possibilities, at a very affordable price tag and in top of that, with extyerme good quality.
A perfect add to your diorama or a simple vignette.
Very Highly Recommend
Our thanks to MiniArt for the review samples.
Available in any good model shop – click here.
MiniartLogo-Largescalemodeller_zpsffd70b
