Administrators Fran Posted May 5, 2016 Administrators Posted May 5, 2016 PLUSMODEL 1:35 Diorama Accessories Shed (Catalogue n.º 442) Price Tag: 16.20 €/23$ (Laser carved wooden parts and 7 resin parts) Available from Plusmodel Plusmodel is a nonstop helper to all modelers, specially diorama builders. We are going to look today at the “SHED”. Up, a wooden shed in 1:35 made by Plusmodel. This shed can be use in WWI, WWII or Modern scenery as is all of wood. Plusmodel also give some resin stuff to put inside the shed. You simply can use these or anything else that you have in your stash to go along with your scene. So back to the shed, its came in a small but quite sturdy box fill with wood and some resin bits. The shed itself is made all in wood. For the shed structure and roof joists are also pre-cut wood parts. These parts are in a more thick wood. The sides and back of the shed are in laser cut balsa superfine wood. So in reality, is like the real thing – wood. All parts fit very easily in each other and easily glued with superglue. You actually need to follow the instructions and put a duct tape under. If you don’t do it you will probably end destroying the walls. For the roof and the front of the Plusmodel provides several sections laser cut, so that they can put one by one thus making a roof scaled and very realistic. For the resin parts, Plusmodel gives an ax and a trunk, two wood wheels, one metal drum and wooden crate. The resin is in light gray, with no distortion whatsoever, and bubble free.. Top noch quality and casting as usual from Plusmodel. No colour instructions are given for the resin bits or for the shed. Its up to modeler creativity. Theses resin bits are in fact an extra to the set as you just can use almost anything else inside this shed. As I already had build some wooden crates, I decided to go forward and built this shed… Easy-peasy! Straightforward and no difficulty whatsoever… And it look GREAT! Love it! CONCLUSION: Another must have items from Plusmodel for any modeler who wants to enhance their work. This shed can be used almost in every scenery, WWI, WWII, and modern one. I will probably use mine in WWI! J VERY Highly recommended. With my sincere thanks to Plusmodel for this review sample. To purchase directly, click this link. Francisco Guedes 2
Administrators JeroenPeters Posted May 5, 2016 Administrators Posted May 5, 2016 That's pretty cool! 1
Administrators Fran Posted May 9, 2016 Author Administrators Posted May 9, 2016 Yup JP!! Really nice add to any diorama or simply vignette!! I will add this one to a WnW, i think...
