Umlaufmotor Posted December 28, 2013 Posted December 28, 2013 ...............of course, only a joke ................. right? We all know, Tamiya tape is first-class material for masking.But it can also be used for other things. Here, for example as a Holder for the lubricant pump. A thin strip glued it, painted with RLM02, left and right of the pump two dark spots as screw - done. Or here, on the NW Mercedes D.IIIa - engine, thin strips of Tamiya tape serve as pipe clamps. Pipe sleeve at the cooling water pipe at the Pfalz D.IIIa. A thin strip tape, painted with NATO black.Pipe connection with Tamiya tape, painted with Mr. Metal Color "Iron", glued with super glue. Twisted Thin wire serves as the hose clamp. As you can see, not only as a masking tape - many things are possible with Tamiya tape. ...................... But, believe me - it does not substitute as toilet paper...................... Servus Bertl 5
Administrators Fran Posted December 29, 2013 Administrators Posted December 29, 2013 Bertl you are genius! Thanks for sharing!
wemattson Posted December 29, 2013 Posted December 29, 2013 Bertl, Another outstanding post! Thank you, Wayne
