rverissimo Posted March 16, 2025 Posted March 16, 2025 Hi all! Having already reviewed some of ASK’s masks (here) and with the ICM 1:48 UH-60A available, ( review here) I decided to roll up my sleeves and apply the masks to the windscreen. The application scheme is easy to understand, as each mask is numbered. The process is quick, and the masks fit perfectly to the corresponding “glass” of the windscreen. . After 10 minutes, the exterior masks were in place The interior part took a little longer, as it does not have frames to align the masks, unlike the exterior ones. However, simply using the external masks as a guide ensures proper alignment. And there we have it—a windscreen ready for painting and fitting into place. The masks performed according to their quality. The sections that outline only the glass require occasional adjustments, but I attribute this more to the modeller’s skill than the material itself. They can be removed and re-positioned without losing adhesion. So, here is a small step-by-step guide for applying ASK’s masks. Thanks for watching ! Ricardo Veríssimo 2
KevinM Posted March 17, 2025 Posted March 17, 2025 Thanks Ricardo looks pretty good from here the only thing I have used of ASK is some of there swastika decals while good but very thin had to use more than a couple for the build. 1
