I usually pride myself on paying attention to detail, however I have a habit of being humbled once in awhile. Which is good, since it keeps my head from becoming "Zepplin-like".
While admiring all the great Eindeckers since the build started, I just now realized I see no flaps! No flaps, no ailerons, no elevators. Not even a trim tab! What I did notice, is an interesting looking curve to the wing, an odd place to locate a pulley, and what appears to be a major pivot point where the wing would normally be attached to the fuselage.
Am I correct in assuming that the wings themselves were the control surfaces? That by moving the stick, the commands would travel via wire, through that oddly located pulley, and pitching the entire wing into the proper degree of inclination or declination?
:huh:
Eindeckers were 'wing warpers' - where as most of the rigging was used to brace the wing in position, said pulley allowed the upper outer wire to move from side-to-side whilst maintaining tension as the lower wires were pulled or released by the yoke mounted at the back of the undercarriage. It worked, but not particularly well, which is why the concept was abandoned.
Fascinating. I thought, but didn't want to say 'wing warper' because I wasn't sure. The fact that anybody would conceive of such an idea is mind-numbing!
After posing this question yesterday, I took the time today to read up some on the 'wing warping' concept. I didn't realize that Anthony Fokker was somewhat behind the curve in this design. Apparently it was the "norm" when it came to aircraft design. Interesting what you can learn from admiring models!
Even perhaps more interesting is that ailerons, rudders and elevators are all derivations of the original bird concept of articulating surfaces to affect directional change.
