Wingco57 Posted May 5, 2014 Posted May 5, 2014 Will you build the Tiffy OOB or do you intend to use MDC aftermarket? Cees
RalphSarc Posted May 5, 2014 Author Posted May 5, 2014 Will you build the Tiffy OOB or do you intend to use MDC aftermarket? Cees Not sure yet as I'm working on my Ju88 but I did pick up some 1/32 aftermarket Tiffy decals on eBay just in case. The kit is Revell # 85-4663 1996 depicting a Hawker Typhoon Mk 1B "Mavis" flown by Flg. Off. LWF "Pinky" Stark, No. 609 Squadron based at Manston early 1943. That's how I will build it. Ralph. 1
Dave J Posted May 20, 2014 Posted May 20, 2014 I have that Tiffy kit too, plus all the MDC resin bits... My plan is to rescribe the kit as it has raised panel lines... But knowing my luck someone will release a newly tooled kit!
RalphSarc Posted May 21, 2014 Author Posted May 21, 2014 I have that Tiffy kit too, plus all the MDC resin bits... My plan is to rescribe the kit as it has raised panel lines... But knowing my luck someone will release a newly tooled kit! My next build will be my P38J kit and then the Mossie. The Tiffy is a bit out their yet probably in October!!
