Administrators Fran Posted November 27, 2014 Administrators Posted November 27, 2014 Hi!! Well, I have this Junkers J.I in the shlef of doom... for quite a long time... i started this one in Modelscala 2014, as a challenge to build a Junkers J.I in 48 hours... I totally miss the goal... and since then, this Junkers has been put aside, abandoned to his luck... So, I just decided to do that... a Dio with this baby left to rush..... So, my scenario is in 1921, somewhere in Germany, with a forgotten Junkers J.I... ****** Hi Guys!! i`m joing this one right at the end of it I know.... I started this one in the WnW Marathon that took place in the end of September.... Now I going to give a try to finisgh it in 2014... 2
Administrators Fran Posted November 27, 2014 Author Administrators Posted November 27, 2014 and here is how it is right no (the work of two half days, on the Marathon): So I`m going to pick up again on this one and try to finish at time!! 1
RalphSarc Posted November 27, 2014 Posted November 27, 2014 Excellent!! Looking forward to watching your posts. 1
One-Oh-Four Posted November 27, 2014 Posted November 27, 2014 Ah, looking good, Francisco! Show us more!! 1
JonathanReed Posted December 7, 2014 Posted December 7, 2014 Nicw start Francisco! Lets see it finished! 1
Administrators Fran Posted December 12, 2014 Author Administrators Posted December 12, 2014 A small update: Here you can see probably the biggest (and only) error on WnW model kits. The aileron is too short... or is the central wing... there is some discussion on the web... I use the sprue D parts available... but i forgot of the downside... My fault... so I do have to go other way around and use the unused rudder... The texture is not exactlly the same but it will have to do. Both sides almost done!
Spandau Posted December 14, 2014 Posted December 14, 2014 Looking forward to seeing the completed model! 1
RalphSarc Posted December 15, 2014 Posted December 15, 2014 I've watched with great interest all the WNW builds and wonder where in the US do you order all the aftermarket stuff used in these builds. I notice the brass hinges for example, where do you order those??
Administrators Fran Posted December 15, 2014 Author Administrators Posted December 15, 2014 I've watched with great interest all the WNW builds and wonder where in the US do you order all the aftermarket stuff used in these builds. I notice the brass hinges for example, where do you order those?? Hi Ralph! Thnaks for your words. The hinges are from the kit! i have put then in different position because I saw some archive photos that show then in different positions. This build is OOB with the exception of the seatbelts that are from HGW.
Administrators Fran Posted June 6, 2016 Author Administrators Posted June 6, 2016 I will post some new pics... and some things will have to be changed... the first of all is taking the engine out...
