elmarriachi Posted March 2, 2015 Posted March 2, 2015 The interior after full painting with oil colors and polished metal parts. The seatbelts come from HGW, made of fabric and PE parts. Looking much better then the PE parts from the kit, but the work is very, very "funny" The displays received some "glass" made of Crystal Clear, the rest is all painted with oil colors. And the interior testfitted in the hull. Goes together very well. Seems that no putty will be necessary here! The finished engine. Added some wiring and some tape, painted, weathered with oil color washed, dry brushing and pigments on it. Leaked oil will follow. Next step.... finishing interior and adding the rigging inside. Also the fuel tank, ammo-boxes follow before putting together the hull-halfes. Cheers Michael 1
elmarriachi Posted March 9, 2015 Author Posted March 9, 2015 The two halfes of the fuselage where glued together, little putty, little bit of sanding, then primer with a light brown / beige airbrushed over it. Then I tried the wooden decals from HGW for the very first time, cut out the panels and put all of them on the fuselage. After some time of drying I added a layer of clear coat to protect the decals, then added the nails (decals) from HGW. The protection foil on these decals damaged the wooden decals under it, I do not know why.... So I will have to do some repairings as next steps. Next steps: Repairing of the wooden decals, then clear coat, then oil colour for the final finish. Cheers Michael
elmarriachi Posted March 13, 2015 Author Posted March 13, 2015 The hull received a layer of clear coat to secure the decals before the next steps. Then - oil color (burned umbra) was applied with a brush panel by panel and worked in with a cotton stick. Next step - a layer of clear coat to secure the oil colours, then the details will be brush painted (grey-green) and the decals and markings will be applied. Cheers Michael
elmarriachi Posted March 19, 2015 Author Posted March 19, 2015 The wooden effect is finished! After the dark brown (burned umbra) oil color is worked on the decals, a layer of clear coat is added to protect the colors. Then the details were painted - grey/green at the front and small details, black at the back of the fuselage. Then all the Decals were added and a further layer of matt coat added, then a cloudy layer of glossy clear coat sprayed over. The rear wings painted white, masked and painted black. The details on it follow later with Tamiya Smoke. Next steps: Painting of wings, guns, small parts on the fuselage. Cheers Michael 2
Administrators Fran Posted March 20, 2015 Administrators Posted March 20, 2015 Great work on the wood!!
elmarriachi Posted April 2, 2015 Author Posted April 2, 2015 a short update for the Albatros. The painted and weathered wings (oil color washs white and black) as well as some pigment powders later, the wings were mounted. I think the upper wing is a bit tricky and needs some dying time before going on. I have glued spot by sport ... The engine cowlings mounted, the wheels as well. The wheels are first painted in silver, then masked with maskol, then painted in grey/green. Later weathered with oil colors. Next steps - propeller, last parts, rigging ... Cheers Michael 2
Administrators Fran Posted April 3, 2015 Administrators Posted April 3, 2015 great work!! Almost done!!
