Administrators James H Posted June 21, 2018 Administrators Posted June 21, 2018 1:35 U.S. Tank Crew MiniArt Catalogue # 37005 MiniArt really do create some superb sets to aid the diorama modeller, whether it be something as simple as a wartime domestic scenario, or the popular vehicles and figures combo. We recently reviewed the East European House Stuff kit containing table, chairs, and domestic items, but today we’re going to zip forward a few decades to look at a set that’s been designed to complement your U.S. armour builds. Photo courtesy of We Are The Mighty Whilst it’s quite vogue at the moment to produce armour with full interiors, the majority of kits on the market don’t possess that level of internal detail, yet still allow the modeller to pose the various hatches in the open position. Maybe not too good for a solitary vehicle on a display shelf, but certainly perfect for adding some figures. This new set from MiniArt depicts FIVE modern U.S. tank crewmen, and would be ideally suited for displaying with one of the many Abrams releases, for example, or indeed any other piece of modern U.S. armour (Bradley, Stryker, M1117 etc.) The kit itself is packaged into an attractive end-opening box which has an image of the combatants on the front, and an individual painting guide on the rear, despite the fact that the crew themselves are very similar in outfit. These rear illustrations also serve as an assembly guide for the crew, with the poses being clearly seen and the parts/appendages numbered for clarity, with a sprue letter annotation. The camouflage fatigues themselves are actually finished in a digital camouflage, and this could be difficult to recreate, but I’m sure there must be a few tried and tested techniques to produce this, including decals from companies such as CrossDelta. Inside the box, a single clear sleeve contains five sprues (3 of which are joined by a master sprue length), and each of these sprues contains the parts for one single figure. Moulding is excellent, with just the inevitable minor seams lines to scrape away, and the breakdown of the figures is obvious. Having separate heads, you can of course pose these even more dynamically so as to perfectly fit your diorama. Helmets are also moulded separately to the heads but leaving a full head underneath in case you wanted to pose the helmet off the crewman. A few other accompanying parts are included on each sprue, such as weapons, mic booms etc. Detail is superb, with realistic fabric folds and creases, boots/straps, and torso padding. Not much can generally be seen of the faces due to the uniform. All poses are very organic/natural in appearance and would suit just about any application you have in mind. Conclusion A simple yet effective and detailed set that should sate your appetite for U.S. armour dioramas. The set itself is also quite inexpensive, and most certainly in comparison to resin figures. Assembly is a breeze, and it’s just the camouflage application that you would need to overcome. In all, a seriously nice release. My sincere thanks to MiniArt for the review sample seen here. To buy this kit, check out your favourite local or online retailer. 2
