I know this may be early as I have only had the kit in my sweaty mitts for a couple of hours, but is there any talk of 1/32 Lancaster masks on the horizon? The usual suspects can chime in here......
Undoubtedly there will be a mask for the HK kit. I can only guess that this will be around £15 if not more
I for one, cut a mask for my 48th Lancaster, canopy and turrets, and I can see that it would be even easier on a 32nd with the clearly defined lines.
I even put in a canopy frame in the 48th which again I shall consider (photo to follow) for the 32nd.
Personal choice I know but it a  case of doing it slowly and checking regularly that it touches the cockpit frame as it should.
David
