This one's been on the go since '07 (my usual glacial buuild rate) but yesterday I dug her out for a looksee and made lots of progress (for once!):
Inner walls double skinned with corrugated plastic sheet and brass box section side rails added to straighten the sides:
Start made on more bulkheads - rectangular 'blanks' of correct width made up - and one 'notched to fit around brass 'rails'. Later I'll shape to fit roof and cut out middles - so the form upturned 'U' shapes:
New doors made/cut out to convert the fuselage to correct mark of Ju52:
Wing roots boxed in with plastic sheet cut oversize - will be cut back and shaped to profile later:
Wings loosely on - only a few minor tweaks need then fit's a good'un...
All control surfaces now prepped and bonded together:
Wheels assembled, spats assembled, cowl rings cut out and replacement canopy sourced from a spare Combat Models kit (hoping the original will turn up somewhere):
Fuselage top - next stage gun mount opening:
And reinforced internally with more corrugated styrene sheet:
Back later (prolly with some other random project! wink.png )
Iain
Iain,
Wow talk about a trip down Memory Lane. I'm glad to see you're back at this big bird my friend. Looking forward to the next update.
Highest Regards,
Gregory Jouette
*I'd* almost forgotten about this one!!
Thanks to a little sunshine I managed to get the last two exterior window sills replaced - so now back on models...
Thought someone might find my method of adding windows useful (you never know!)
Using a brilliant sheet of clear acrylic sheet (Bayer Vivac) = beautifully clear it comes with both sides of the sheet coated in a blue protective film:
New panes are cut using the openings as a template:
Once happy we have panes that fit - remove the protective film - and it's out with the black permanent marker - once around the outer edges of the clear pane and once around the window opening:
Excuse the finger prints!
All fitted nicely in place a fine brush is used to flow Plastic Weld into the joints from behind - pointing the brush sideways in towards the joint on the white plastic side (not the acrylic - marks easily!):
And Bob's your Aunty:
Panel loosely tacked in place - panes will be polished with Plastic Polish before masking again ready for paint:
Right - back to the slog...
Iain
Further progress...
Internal frames shaped to fit under fuselage top section and wing root areas cleaned up after boxing in:
Starbord door and window section prepped and 'windows' removed for glazing
Wing roots trued up and pretty good fit now!
Iain
