Looks that They try to make a new model kit... Maybe we can buy only the set.... Forget the Meng! Loooool!
​Yes, Voyager goes beyond the need. But…….they are somewhat reasonably priced. I am using their set on my Tiran 5 as we speak. Not the full set, just the basic. You have to put yourself in the mindset that you are not going to use the whole thing. They are the easiet pe I have ever used. Easy to bend and form and most important, minimal attaching points on the fret. That helps a lot in cleanup. I use the X-acto #9 knife and blade exclusively on pe. Small and extremely sharp.
Think that is nuts? Check out Voyagers track set for the LVT series vehicles.
Don't get me wrong! I like Voyager PE, because They are not to expensive and very easy to handle. But i also do think that sometimes, They go away beyond the need... I think just for looking (because i do not have the FT17 set) that this is beyond the need...maybe i'm wrong!!! :)
