Hi all,
The underside if the upper with has been pre-rigged with the flying, landing, incidence, drag and cabane bracing wires.
For rigidity the landing gear has been final rigged with its bracing wires.
Mono-filament of 0.08 and 0.12 mm diameter used with 0.4 and 0.5 mm diameter blackened Brass tube.
The turnbuckles on the landing gear are 'Gaspatch' 1:48th metal Type C for strength.
Now it's onto fitting the upper wing,
Mike
Hi all,
Apart for some areas of weathering needed, the aircraft model is finished.
The last parts have been added:
Wheels ('Proper Plane' 760x100 'Continental')
Propeller ('Proper Plane' 'Garuda')
Windscreen
Aileron controls
Observers Parabellum machine gun,
Flare ammunition rack,
Grenades rack,
Flare pistol.
All structural and flight control rigging completed.
This was 0.08mm and 0.12mm diameter mono-filament and 0.4mm and 0.5mm diameter tube.
Also 'Gaspatch' metal and 'Proper Plane' resin turnbuckles.
Below are a few shots.
Now it's onto the figures,
Mike
Hi all,
Pilot and observer/gunner completed
They are the ‘Model Cellar’ WW1 German two seater crew (MC32016).
The finished model shots will be posted soon,
Mike
Hi all,
Completed model shots are now up in the WNW Ready for Inspection thread.
Thanks for your comments and support during this build.
Now to continue with the Hannover Cl.II build,
Mike
