Looking forward to building the Bradley. This will be my first armor buiuld with an interior!
3590F27A-A9E1-43E3-9879-BF155F80AAA5_zps
0FF2C43A-6528-4BA5-832B-FFC75673AC6D_zps
0AF0C275-99C7-4920-892D-DBB699B35845_zps
8B0B5962-7D8D-4B2F-8F66-7E9F03BC1524_zps
4F312EC6-DD7F-401E-8481-053BB8F75B7D_zps
BC2E354C-3645-41E1-8F80-EDEE0F219638_zps
A4B87E6C-88D7-40F9-8535-69BC54CC5E0A_zps
03014840-1A67-42A2-AF23-49BBB04D86E3_zps
Bought these few items for the build!
A4BD7DF9-B905-4CB1-97B8-466F11A8B7F3_zps
Started building the lower hull and lift gate doors today, Actually had to sand injector pin marks and part number from parts 69 and 70 that would show when installed!!! Haven't run into that with Tamiya before!!
75BD1532-3AA4-41B4-9FF5-98B97189B5C2_zps
Installed all the parts lined out in steps 1-2-3 however left the circled parts such as road wheels etc until the end of the build.
D8F6FECD-4B0B-43EE-A17F-72602EA6C027_zps
D33D3C6C-E406-4934-9ABD-38F489B00BD3_zps
Installed all the parts in steps 4-5 but again left the road wheels. The rear lift gate fit like a glove!!!
Also installed the interior floor and the two large poly caps which hold the two hull halves together so you can separate to show off the interior.
I'm going to wire the interior and make cushions for the seats!
27B2C3FD-4A3B-40DF-96EE-CE8C6BF56436_zps
99A73057-7EC7-4D43-A0D2-1932C789407D_zps
E99883D6-BE77-45D9-9958-038662A707DA_zps
6975A89E-9290-4E75-9822-360CA8BF9E77_zps
This is going to be such a detailed kit, lol!!
1EDC1C59-EA8E-4959-9E0F-2976B9510B5E_zps
Thanks to Arno I was able to print miniature maps and magazines for the interior of the Bradley!! Pretty cool!!
04152146-7329-44DE-873E-3475B66642AF_zps
Finished steps 7/8 today and continued on with the interior build. The parts circled I'll detail and install later. Once I install all the interior parts I can I'll prime the upper and lower inside hull parts with white primer pre-shading with Tamiya XF-9 Hull Red and then applying a base coat mixture of XF-71 Cockpit Green and XF-2 Flat While.
0A7CEC90-DFBA-4355-AD4E-D72A00FF8A7E_zps
C939D893-3118-4679-98F8-CD8B13E586C3_zps
D3FFB2CB-3ED9-49D3-99F3-BE8562092A73_zps
Finished step 9 this morning by building the side wall to the drivers compartment and the turret tub!
e6622681-28c5-4b24-89c8-0043cc82a087_zps
81E7B5FE-AF76-467F-8459-A3F322672042_zps
The interior spaces will look so cool when complete. I'm considering wiring two LED lights in the interior to show it off!
00757D4A-2193-410A-B4BD-D3AB68964E00_zps
Well after a long day at the hospital for Beth's tests I needed some quite bench time to reflect!!
Completed steps 10/11 which finishes the lower hull build. Once I complete step 12 I can begin the interior painting process!!
I also mapped out a 9V LED lighting plan for the interior using two green LEDs, a 100 ohm 1/8th watt resistor, a micro on/off switch and a 9V battery connector. Should look pretty cool!!
C0370962-A899-4487-865C-A4AD60AAE66C_zps
Driver and radio operators compartment.
3674E6B2-C2ED-495D-A628-A30B61C2E8A2_zps
Crew Compartment.
5C8FD0E4-96F2-40E6-BF8B-AC000BD05038_zps
A view in the rear hatch.
0BF9B3F2-AA84-4297-B876-37A7AE3D8C8E_zps
Well back to it, lol!!
Okay finished installing all the parts to the top interior hull in step 12 so it's off to the paint shop for both the upper and lower haul for priming, post shading and interior base coat!
CCFFDDFF-CE31-4884-B67E-9C8AD11C33D1_zps
Ready for priming!
6EAE2B0D-1F34-4914-BEFE-F0DA743A1221_zps
Since my paint shop crew is off for the weekend I'm doing my own priming, post shading and interior base coat!! Hope I do it right, lol!!
BF47191E-CD0C-4657-AA4D-6680A0F95FE0_zps
lright primed both halves of the inner hull with white rattle can Home Depot primer I pre-shaded with Tamiya XF-9 Hull Red and XF-1 Flat Black. Once that dried I applied a base coat mixture of XF-71 Cockpit Green and X-2 White. I let that dry and then post shaded with X-2 adding a few drops of XF-71.
91A48174-D25F-486D-B57F-11116395942A_zps
Spent a few hours this afternoon painting and detailing the interior. Still lots to go!!
E7E18C94-BC90-482D-9389-528ED5EB8DAF_zps
Continuing on with the detailing of the interior. Just added some camouflage knapsacks and stowage bags for interest!
I camouflaged the stowage items using Taniya XF-10, XF-62, XF-49 and XF-1. I have many more that I'll attached on the outside hull!
CAA6BEAB-7A33-4023-8F84-0D878D0A5AE4_zps
I'm liking this!!! Time for a wash and then Future coat but that can wait until tomorrow!!
C452A24E-5B10-424B-9446-621B5848747D_zps
Ralph,
Looking real good. Keep it up.
Wayne
Hey thanks Wayne!! I was starting to think no one was checking post any longer, lol!!
Completed steps 13/15 last night and this morning. The rangefinder clear part was a bit fidgety and the smoke discharge system was just to small, lol, but all in all pleased with the turret assemble so far.
Painted the turret interior and inside hatch covers with Tamiya XL-71 Cockpit Green to match the interior also.
42F20982-F072-4D7D-9494-337CA8C13CA3_zps
4413D00B-77CE-4F48-90AB-4C49C7A24F8D_zps
Finished step 16 and the turret build.
28E5C005-2E8D-4EA8-AFBB-F74394FA0B10_zps
0BB19C5E-464B-4E64-BF63-A5EFBA174103_zps
Finished installing the interior decals and applied a matt coat to seal it all up.
18652621-6951-4ECE-8CD6-54CCEB79F2B7_zps
Well today I hope to get all the small bits on the hull before closing everything up and sending the Bradley off to the paint shop for priming with tan rattle can primer, pre-shading with Tamiya XF-9 Hull Red and possibly a base coat mixture of XF-59 Desert Yellow and XF-57 Buff with a few highlights of XF-49 Khaki.
FD337FBB-7BC1-4666-A8D2-174DFEEF4B0F_zps
A cold rainy windy day here in Georgia means lots of enjoyable bench time. Did a bit of scratch built brass grill and stowage basket detail this morning. The brass will look better than the black mesh included with the kit!
1A3D3DA9-FA9B-4A36-8D31-0D40460F4600_zps
Completed front hull grill.
0892AFD2-E0CC-44BF-BA5D-6AFA86F51A9C_zps
Brass basket looks better!!
22168493-99DD-4113-BF17-9F1F2B06F02F_zps
Finished step 17/18 adding all but the tools and a few small items I'll add after paint.
0E098074-E5DE-402D-9858-70289D4BB478_zps
B09DD3CB-46E9-41B6-89F7-F09B8B68D15A_zps
Headed to the paint shop for priming and pre-shading!!
FBD7BF16-6375-4C2C-9AF0-DCF4FD347049_zps
Primed and the paint crew also painted the road wheels flat black so I guess I'll be painting hubs tonight, lol!!
D25F66E7-8639-445E-8BD8-7FE082EB74D1_zps
Finished pre-shading with Tamiya XF-9 Hull Red and a few areas with XF-49 Khaki.
ADA039C1-7FD7-40DA-8302-5C5EC2D52206_zps
Once the pre-shading dries the paint shop crew sprayed a light coat of XF-59 Desert Yellow and a post shading coat of XF-57 Buff.
85A61329-2D83-4470-9C10-FBCFB955BAF8_zps
Ok I really like the effects the paint shop crew was able to achieve. Looks real sandy!!
2D0C77F7-7796-47AA-A87A-7181EC5B6719_zps
Looks good with the rear hatches open.
Well on to the road wheels!!
ED73EEFA-0F45-4971-A468-584B413C11D1_zps
Ralph,
The detail in that kit looks real good. You did a great job on the interior. I'm going to have to start building som armor.
Wayne
