Woodshedwings Posted April 17, 2015 Posted April 17, 2015 Is it possible to soften miliput that has, over the years, become a bit stiff. I know it can be smoothed with water, but will water soften it sufficiently to be able to mix it. I'm talking about un-mixed milliput here, in case people thought I'd gone a bit daft. 1
Administrators JayDee Posted April 17, 2015 Administrators Posted April 17, 2015 Have you thought of spraying it with water, popping it in a food bag and tying up, and then leaving somewhere warm? The humidity might soften it again. 1
kuya Posted April 17, 2015 Posted April 17, 2015 Mine the ends are hard not pliable and was about to throw it away I didn't of think water !
radub Posted April 18, 2015 Posted April 18, 2015 In the past, I had bad experiences with old miliput. What happens is that it breaks into small "crumbs" that do not mix with the other component and remain uncured. The result is a surface with with uncured spots that are impossible to process (sand/file or scribe). Personally, I would chop and cut away all hardened bits from each stick until reaching the soft core (if any is left) and only use that. If the whole thing is gone hard and brittle, I would not use it. Radu 3
Wingco57 Posted April 20, 2015 Posted April 20, 2015 I agree with Radu, Had some very bad experiences with that. It either wouldn't get hard again or crumbled and was impossible to sand (talking about Milliput here ). Better safe than sorry. Cees 1
Woodshedwings Posted April 20, 2015 Author Posted April 20, 2015 It looks like I will be binning it and getting some more. Thanks to all for the advice.
