Brassin 1/32 F-104A/C/G "Early" Exhaust Nozzle
Available at many good online-stores or directly from Eduard for €14,95.
The Starfighters from the YF-104 up to and including the F-104G were fitted with this type of exhaust nozzle. At one time the German Air Force put their F-104G engines through a modification process that also resulted in the adoption of a longer -and different design- of exhaust nozzle. The same type of "late" nozzle was also used on the F-104S. Brassin also has parts for that exhaust, see the review by Jeroen Peters. In any case the Original design has been used on the majority of (T)F-104G's throughout their life and on all F-104A's, F-104B's, F-104C's and F-104D's.
The set is superbly cast with very fine detail. I just consists of 2 parts that are used in conjunction with the afterburner section of the kit.
The outer nozzle:
And the inner nozzle (the one that is responsible for the legendary Starfighter whistle):
Compare that to the original kit part (although that also includes an inner nozzle, not pictured here):
Dave Williams, Largescaleplanes
It's evident that the resin parts are much finer than the kit parts.
Check it out against these photos of the real thing from the SBAP website:
Serge van Heertum / SBAP
SBAP have a very fine walk-around of a Belgian F-104G on their site.
As you can guess, this product from Brassin comes Very Highly Recommended.
My thanks go to Eduard for providing the review sample.
the hyperlink works perfectly! ;)  ;)
Great review by the way!!
