1:24 Istanbul tram
OcCre
Catalogue # 53010
Available from OcCre for €96,45
1.thumb.JPG.17bc44a3fd27ef561eaea79676f4
Istanbul, the former capital of the Ottoman Empire, once had a large tramway network on both the Asian and the European sides. It first started as a horse tram in 1860 and was gradually converted to an electric tram system starting in 1912. Many additional routes were added to the tram system, in progressive stages over time. The network reached its most widespread extent in 1956 with 108 million passengers being carried by 270 tram-cars, on 56 lines. However reflecting developments in many cities around the world during the 1960s, the tram service began to be closed down in 1956 and was completely stopped in 1966.
The Authority thought to re-introduce heritage trams in Istanbul using the same type of rolling stock which was running in European part until 1962, and in the Asian part until 1966. The original Istanbul tram network was almost completely destroyed, including depots, termini, electric power stations, etc., except for some of the rolling stock which had been preserved in transport museums. Using old photographs, people's memories, and other sources, some rolling stock was built for the European side resembling pre-1962 European-side tram stock, including the size, shape, interior, colour scheme etc. The prototypes had originally been built in 1915. Around 1990, the Istiklal Caddesi became a pedestrian zone, and the tram was restored and revived in 1990, in the form of the Taksim-Tünel Nostalgia Tramway. After a 24-year absence, trams returned to Istanbul. The length of the line is 1.64 kilometres (1.02 mi) and there are 5 stops.
tram.thumb.jpg.535dbfd70ca00639df0a42720
The Istanbul nostalgic tramways are two heritage tramlines in the city of Istanbul, Turkey. The city has two completely separate heritage tram systems, one on the European side (the Taksim-Tünel Nostalgia Tramway, aka. T2 line), the other on the Asian side (T3 line, aka. the Kadıköy-Moda Nostalgia Tramway).
The kit
2.thumb.JPG.4450b8ae4651ad29662eb43d260f
OcCre’s new Istanbul tram kit replicates one of those heritage trams mentioned in the passage above, and is packed into a slender, standard OcCre box, as per our Terror articlethat we published recently. A colour-printed wraparound label is affixed to this with tape, and a cut-out in the lid is designed to display the plastic tray of components within. Lifting the lid and removing the inserted component tray, we come to the main box and here you slice a few tape tags to open up the contents.
3.thumb.JPG.507d2c3259a285f876ce6d972597
All the timber parts are bundled with two sheets of photo-etch parts and are securely held together with a shrink wrap covering. This compact method of packaging ensures zero damage and all parts are pristine. Now we cut away the cellophane…
4.thumb.JPG.c6d3f3133b6362eaa2ea41220b75
This sheet of parts, all cleanly laser-cut, concerns the construction of the tram seating. Each seat is comprised of four parts, varying slightly, dependant on where in the tram it is installed. Note that no parts are engraved with numbers. Instead, you will need to refer to the printed parts plan that is a part of the assembly manual. Timber quality here is high, and all parts are only held in situ with small, easily cut tags.
5.thumb.JPG.aa85ac74b163dd7959fbc083d309
We now have an MDF sheet included. This one contains a number of parts for which removal of wood grain would have been a PITA, so this is a nice move. The largest part is the tram floor, with various slots and connecting tabs, roof side supports, roof end frames and roof support frames etc.
6.thumb.JPG.d1a57462a71269d9d9276b9acbf8
7.thumb.JPG.45e22c25e6f30dfb914ace64ed50
Our next two plywood sheets are identical, containing frames, cabin ends and internal frameworks, more seat parts, door parts, bulkheads, etc. Each sheet contains over 30 parts, again, all cleanly cut in high-grade ply. Laser scorching is very low, and very localised, and char clean-up should be nice and easy.
9.thumb.JPG.b65067e63a0103b9f95d00e2fd02
The next two sheets are also identical to each other, but instead of being produced from ply, these are also supplied as MDF. This is actually quite a savvy move as I mentioned, as a good number of these will go into building exterior areas of the tram, and of course, there will be no wood grain to remove. Here you can see the slab sides for the tram, more roof frames, boarding platform and chassis frames etc.
10.thumb.JPG.2d34c559ba20f525c72a5fb92ec
11.thumb.JPG.943d845c41b3f7cd4f0e3f36db0
A nice thick bundle of various size timber strip stock is included and bundled together with elastic bands. This material will form areas such as internal framing and the planked roof etc. Quality is very good, with only a little wispy material needing to be removed from some of the strip.
12.thumb.JPG.afefeb3b92a415c9d4787ee79f9
13.thumb.JPG.8785731450a3a6bad2ebd5567e7
That’s the last of the timber areas in this kit, as we now look at the two photo-etch sheets included here. The first one is made from brass, and includes the instantly obvious shutter gates, tram destination sign brackets, external window frame corner trims, etc. Etch quality is superb, with the removal tags being thin and narrow.
14.thumb.JPG.fa355cb6b6b1f859dd9ffd668f5
The second PE sheet appears to be manufactured from some sort of nickel-alloy, and parts here include the boarding step housings, electric roof sheathing, cabin parts, ventilators, external footplates, and also hand rail mounting points.
15.thumb.JPG.e6b2c9e20c95574ca77d30110a1
A number of lengths of thick brass wire are included for fashioning all manner of items, such as the trolley pole that catches the overhead electrical lines. Some of these items will need straight edges, so you’ll need to be careful when it comes to ensuring you straighten the wire suitably. I do think that some of these wire items will really lend themselves to being soldered, so if you are capable of that, it’s time to ready the hot iron!
16.thumb.JPG.b7f97b90c0edda3ef73d6b65bae
I admit that I didn’t really know how the exterior livery was going to be approached on this model, such as paint, decal etc., but OcCre have in fact included a nice, glossy sheet of self-adhesive panel stickers that should adhere nicely to the smooth MDF surfaces. These have the livery and text already in situ. You will need extreme care in applying these to ensure they line up perfectly, as I don’t know just how sticky they are. Printing quality is excellent, and this really will create the appearance of the tram you see in the photo at the start of this article.
17.thumb.JPG.7dc3fca0b3603f7b3dbb76eb33a
For the windows, a sheet of acetate is included, and for the internal ceiling, another printed sheet is included. This needs to be glued to the internal roof framework before fitting the various ceiling lights and ventilators etc. I do suggest you don’t use any glue which is too wet and would damage the thin paper sheet. Look at using a quality glue-stick instead.
18.thumb.JPG.64da82d759c84cc3500d1722cd9
19.thumb.JPG.fb231f47222035bc69a4773d1e4
20.thumb.JPG.e8f153837399e403d0c4e4498bb
21.thumb.JPG.fa453179dd10eb3a4bd32e4cfdf
22.thumb.JPG.4c1317577bd06e9070fce85a66d
23.thumb.JPG.979c8d73defaa2dea48da593db3
Now we can take a look at that neat plastic tray of components that we can see through the box lid. This is split into twelve compartments, with each holding either a singular type of item, or multiples of different elements. Many of the parts in here are made from cast white metal, such as leaf-spring suspension, interior lights, dampers, cabin components, wheels, couplings, lights, grab-rails etc. There are a small number of turned brass parts and screws in here too, as well as brass eyelets, washers, and a spool of rigging cord to simulate the electricity cable for the trolley pole. There is a small ply sheet too, with just four small parts for an external roof ventilation opening.
24.thumb.JPG.4a64b6f0ce59d215c69a5221420
25.thumb.JPG.77ebfe28c8472320caa03c8058f
26.thumb.JPG.a8910ec2f8dde9c662f0177841a
27.thumb.JPG.fd32825f3c1251f9fd195655045
28.thumb.JPG.f07eee45f5b99b129b81c05a45f
29.thumb.JPG.62b10dcb2e5bd9226ffcc738828
30.thumb.JPG.69eb3d1502abc350cb530737f6d
31.thumb.JPG.3ee171bb6ee8cab461afd2d7343
32.thumb.JPG.608c06ff732d6e7ad2943a76461
As with the previous OcCre kit we looked at, the instructions for this release are all driven by clear colour photos of each stage, showing actual construction of the prototype model. This series of colour, foldedr A3 sheets goes through the building process in a clear and organised way. It’s also worth noting that the parts themselves are added to the mix in a sequential way, meaning it’s easy to trace where in construction a particular element is required. All stock timber sizes are also shown in dimensional form too, to ensure you use the correct material in the appropriate area.
33.thumb.JPG.aa39b4f402e1b1ab4048e5489f4
A set of written instructions is also included, referring to the specific photos.
Conclusion
This is certainly an unusual and well-executed little project from OcCre. There’s quite a lot of construction to be had here in both frame and PE, with a more than generous number of extra fittings thrown into the mix. A thoroughly detailed and nicely designed model of a famous heritage tram, and one that I image will be addictive to build. Just as well there’s a whole fleet of world heritage trams to choose from! Maybe we’ll look at a couple more soon.
f1.jpg.336bbdc84616b0070559748c87fb3cd1.
f2.jpg.8fdd0b677a4464316389182d1767fc5c.
f3.jpg.88139f3ee5e6123402af17ff94a0db99.
f4.jpg.8c6e566b27646c1df18317c365becb1a.
f5.jpg.4e16e2624cc49eb1af2ae4adc6133ad3.
My sincere thanks to OcCre for the review sample seen here. To purchase directly, click the link at the top of this article.
logo.thumb.jpg.dbe116c7499e14f1650c2a8c8
Nice and original subject. I did see they have a Lisbon tram, with a diorama ... Interesting for a Portguese resident like me ...
