Matt_ Posted April 23, 2013 Posted April 23, 2013 Hello  I'm working on the rear part of a Bf109 canopy.  The machine I'm making doesn't have an aerial mast or the mounting for it.  The Eduard kit has a small hole to mount the aerial.  I've polished off the top canopy framing but am left with a small square depression (doesn't go all the way through).  Any ideas what I could fill this hole in with that wouldn't show (very much - invisible fix is probably not poss.). I've thought of Krystal Clear or PVA, but wonder if anyone has a technique I could blag...?  Cheers  Matt
Grant Posted April 23, 2013 Posted April 23, 2013 I was going to suggest Krystal Clear rather than PVA as it dries much harder. Â What about Future, building it up gradually??
Matt_ Posted April 23, 2013 Author Posted April 23, 2013 Thanks Grant  I hadn't realised Krystal Clear dried harder....  Future is sooo thin when it dries I thought it'd take a long time to build up even a small amount.  I wonder, anyone used the cement watchmakers put glass into watches with...?  Matt
Wingco57 Posted April 24, 2013 Posted April 24, 2013 Humbrol clearfax perhaps, it is rather thick and may fill the hole in one go. Cees
Matt_ Posted May 10, 2013 Author Posted May 10, 2013 Thanks for those suggestions  Once I get back from hols I'll have a go with some glue (I can't glue the Eduard part in as I need a completely transparent piece.)..  Maybe super glue would work as it dries like glass and can be polished....  Matt
WillScarlet Posted June 8, 2013 Posted June 8, 2013 Just a caution using the super glue .......... the super glue dries MUCH harder than the surrounding plastic making sanding it down flush a real pain in the ~~~ ! Â Â Â Â Â Â Â Â Â Â Â But, it can be polished very nice. 1
