So my Fisher September Fury kit is missing one of the prop blades.  Tony mentioned that Sea Furies reengined with Pratt power use a Skyraider prop, so I looked.  The Trumpeter prop isn’t even close, and the ZM prop is close, but a touch too short, too wide by a smidge, and has the wrong shaped tip.
So I get to somehow attempt my first resin casting job.
Question: can a good mold be made from a resin piece?  I need an exact copy....
13 minutes ago, smitty44 said:
Could one be printed?
I already checked, and so far, no. A bunch of compound curves make it tough. It needs to be exact. One different prop blade will stand out huge.
Did my Gotha 4 bladers in metal after a few minor resin casting issues.
I think making another one to fit from scratch is out , easy enough for one blade to be cast..
