It’s been over 20 years since i used model master paints, but, You can test paints by following a procedure. Put a few drops of the paint in a couple cups or paint tray, and add a drop of water to one and a drop of alcohol to another. Mix them and see what the paint does, if you can swish it around and it stays mixed, then it should be fine. If it clumps and congeals, it’s not compatible. You can also try lacquer thinner and any other prepared thinners. Next step would be to brush some on a scrap from each test, let it dry and see if it dries, and see if it is scratch resistant.
