kfutter Posted March 3, 2013 Posted March 3, 2013 This build was a bit unusual in that I started with an already-built model, and decided to strip it down and rebuild it (rather than throw it away). It turned out to be one of my most satisfying projects! Here's what I started with: A bit ordinary, as you can see! Here's what it looked like after disassembly: Not getting any better! And here's what I was left with after stripping the paint off: And now the final glamour shots: The markings are mostly sprayed on, the wheel bays are a mix of CMK and scratch-building, the tail wheel details are CMK, and there's some Hobby Decals stencils on it here and there. Form some reason I only took 3 glamour shots, so here's some photos of the finished model on the workbench: Check out the build thread if you're interested in seeing how this went from A to B. Thanks for looking! Kev 1
Administrators JeroenPeters Posted March 3, 2013 Administrators Posted March 3, 2013 That looks great Kevin. So did you rescribe and sand all the surfaces? Must have.. You sure turned that green frog in a prince!
kfutter Posted March 3, 2013 Author Posted March 3, 2013 That looks great Kevin. So did you rescribe and sand all the surfaces? Must have.. You sure turned that green frog in a prince! Thanks Jeroen! Yep, full rescribe. I also reshaped the gun troughs on the cowl, reshaped the spinner, scratch-built the landing and cowl flaps, and installed gun barrels from Master Model. The main landing gear (legs, doors and wheels) and drop tank came from a Doyusha A6M2 kit, which is destined to become a Rufe some day. Thanks all for your kind words. Kev
