Umlaufmotor Posted November 23, 2013 Posted November 23, 2013 In the spring of 1918, the Balkenkreuz was replaced by the Eisernes Kreuz.Often the Balkenkreuz was painted over with a similar shade of the base color .In our case, WNW sets a light gray color.The kit decal Balkenkreuze " before 1918 " are cut precisely along the black contour.This is very important - so that the transparent carrier film is removed . This carrier film would be otherwise painted and distort the outer contour. Now, the decals are painted with a light gray color. When the paint has dried, the edges and the contour of the rib tapes are shaded with Tamiya "Smoke". Thereafter, the decals are applied to the correct position.Here in this case I used some " softening "Allow to dry and then fix it with gloss clear lacquer.I use to always clear Tamiya paint . When the paint has dried, the new Balkenkreuze be attached.Then seal with clear lacquer and then weathering - done. With this little trick, omitted taping and painting the old "Eisernes Kreuz". Servus Bertl 3
Administrators Fran Posted November 23, 2013 Administrators Posted November 23, 2013 Bertl your woks is an inspiration for me and as Martin said we are so lucky to have you here, on LSM forum. Thanks you so much for sharing your expertise!! Kindest Reguards Francisco 1
Daywalker Posted November 23, 2013 Posted November 23, 2013 Very interesting idea, I like it! Simple and effective- the perfect combination. 1
Administrators JayDee Posted November 23, 2013 Administrators Posted November 23, 2013 Such a simple idea and I never would have thought of doing it. Thanks for posting this. 1
olfogey Posted November 23, 2013 Posted November 23, 2013 As a novice modeler, I DEFINITELY appreciate your tips!!............"Thank You"! Jim J. -- "olfogey" 1
GUY5Y Posted November 23, 2013 Posted November 23, 2013 This forum must be getting the best modellers ever.....loving the posts. 1
JonathanReed Posted December 20, 2013 Posted December 20, 2013 Thanks for the great information! It's priceless getting information such as this from the Pro modellers!
