Umlaufmotor Posted December 25, 2013 Posted December 25, 2013 By the Wingnut Wings Pfalz D.IIIa " the old Jasta37 worn-out workhorse " I had to represent different layers of old (Pfalz silver-gray) and new paint (Jasta 37 black) believable. In factory new condition, the plane was silver-gray over all, the engine cowling was nature metal and the maintenance openings are painted green (close to RLM02 - green).Generally, I try to go the way, to build layers of color in the order as the real aircraft was painted. Back to the maintenance openings :This openings are made from sheet aluminum and painted with RLM02 in the original.It is clear that - over time - , the green color slightly peels off or scraped off .To stay as close as possible to the original, I made the maintenance openings from the aluminum of a simple tea light. A small hole was placed in the middle of the Disk. In this hole, a Eyelet made of thin copper wire was glued as a Fastener.It is better to use a silver wire, I had at that time only copper wire by hand. The Alu-Disk was painted with RLM02. Of fine steel wool and the color was polished off some scratches attached to the edges. This was followed by a layer of clear coat - then a layer of hairspray. Ultimately, even a thin layer of matt black. With warm water and a hard brush the hair spray was dissolved. Now I had black access cover where the underlying coating and the base material were visible. Servus Bertl 1
wackyracer Posted December 25, 2013 Posted December 25, 2013 Once again superb. Thanks so much for putting these posts here.
Administrators Fran Posted December 25, 2013 Administrators Posted December 25, 2013 Seems so simple!!!!
