Mostly finished my airfix 1/24 Spitfire ix. I used Vallejo air series paints. Metal master cannon barrels. Surgical suture thread for the antenna and IFF wires. HGW seat harnesses. Some copper and steel wire and plastic casings for hoses and engine wiring.
I drilled a couple 1mm holes in the engine cowling pieces and inserted strong 1mm x1mm diameter magnets in the cowlings and engine frame so they’re removable.
I used the stock decals for the markings and warning signs but sprayed the stripe and squadron lettering duck egg green. I still need to repaint the crowbar silver though!!
next up, my Airfix 1/24 Typhoon!
Very nice result, your Spitfire looks fantastic and your log was mouth watering, as I now want one.
Congrats on a stunning build, the WIP was excellent, thank you…….you’re on a roll with the Airfix 24th series. One kit I’ve never seen finish is their 24th Mossie…..
I have that one built hanging in my garage! I’m going to bring it up to the house and redo some things along  with the fw-190
  • 1 month later...
Somehow I forgot to finish the green camo on the starboard wing and front side?!??! I noticed when I had it out to guide me on the Typhoon painting
Very nice build and paintjob, you made me thinking once more, about buying the big Spitfire myself.
