mark31 Posted February 6, 2024 Posted February 6, 2024 Looking for more info about the F-4C What is the big difrence between the early and the late. The plan will be to build Robins Olds jet. So far im in the resaerch for this build so i can search for all the parts Thanks
ScottsGT Posted February 7, 2024 Posted February 7, 2024 I did some googling and one of the biggest differences I could find was the Air Force was using Navy style pylons. https://cs.finescale.com/fsm/modeling_subjects/f/2/t/133928.aspx 2 1
ScottsGT Posted February 7, 2024 Posted February 7, 2024 Mark, I’m not sure which pylons the the Tamiya C/D kit comes with, but if you need a set from a J let me know. I just finished the Blue Angels bird and didn’t use them. 2
scott_t Posted February 16, 2024 Posted February 16, 2024 The inboard Navy-style pylons from ResKit are beautiful. 1 1
mark31 Posted February 16, 2024 Author Posted February 16, 2024 17 minutes ago, scott_t said: The inboard Navy-style pylons from ResKit are beautiful. Yes i have seen them but from what i have found for my F-4C it will be the air force style. Going to order them from reskit. Mark 1
Lusitanian Posted March 3, 2025 Posted March 3, 2025 There’s no such thing as “early” and “late” F-4Cs. Like all aircraft, the F-4C underwent progressive upgrades through its production run. And changes were retrofitted to in-service aircraft. What you need to know is, what’s the tail number, and what’s the time period you’re wanting to model it? And you need photographs of the airplane at or near that time to verify things. I’ve done a LOT of research on F-4Cs, so if you have specific questions, fire away and I’ll try to get you a solid answer. 3
chek Posted October 6, 2025 Posted October 6, 2025 Not so fast, cowboy. The final block of F-4Cs (and initial block F-4Ds) were delivered with 'clean' radomes (like the F-4J) with no undernose sensor fairing. The fairings did reappear later. 1
