Just a tip on what I learned this week painting my G Factor brass gear on my He 111.
I did the typical prep with polishing off the casting seams and sanding them down to 600 grit.
Whipped out my trusty Mr. Surfacer primer and blew on a couple of coats.  Came back the next day to do some fine sanding.  Primer was flaking off everywhere the sandpaper touched it.  I could easily remove it with my fingernail.
Dangit!  I forgot Mr. Surfacer is formulated to bond to plastics and other paint.  Wiped it all off with lacquer thinner and went out to my garage and grabbed a spray can of self etching Krylon primer. Funny thing is, it was almost a perfect match for RLM 02
Laid on one to two thin coats and all is good now. Mr. Color stuck to it with no issues.
Gunze  and now Tamiya both make a metal primer that's clear and brushes on. They're both self leveling too which is nice. On a sheet of brass PE, you can see it changes the colour of the metal slightly so I suspect it's self etching but not 100% sure.
