15 hours ago, belugawhaleman said:
Hobbylink had them but I see that they are discontinued now. .......I'll look out for them.
Let me know if you find an inexpensive source.
8 hours ago, FullArmor said:
Nice and safe trip!
Thanks! We’re in PA now at a beautiful state park. Headed to Niagara Falls tomorrow.
Back home and back at the Me410B. Painted the cockpit XF-63 German Grey so I can do some detail painting tomorrow, mask and install the canopy and then prime the fuselage.
Back to the Me410B this morning while enjoying my coffee.
Did a bit of detail painting of the cockpit using my acrylic pens to highlight switches etc.
Good Lord the canopy was a nightmare to align properly!!!
Since the Me410B will sit on a base hooked to shore power cart while being serviced I opted to have one canopy hatch open with the remainder covered with a tarp and possible camouflage netting.
4 hours ago, Landlubber Mike said:
Looking good!  You're really moving along quickly!  Hope the trip was fun.
I’m letting the canopy dry so I can mask it off tomorrow then I can begin painting the fuselage.
I see you have that same little bit on the L/side I thought was a short run and it is a beotch to assemble.
It was poorly engineered to say the least. I can’t tell you how many times I’ve thought about trashing this kit! It’s an awful piece of …….
This morning I attached the cockpit doors using PVA glue plus installed the radio antenna mast. Once all is dry I’ll begin masking the canopy.
I’m kinda leaning to this as a scheme for my Me410B variant.
A beautiful photograph of a captured Messerschmitt Me-410A-3 during a test flight under
RAF evaluation. Note the RAF roundels painted over the original Luftwaffe markings. The Me-410 "Hornisse" (Hornet) was developed as a high-speed heavy fighter and bomber destroyer, designed to correct the disastrous flaws of its predecessor, the Me-210.
The A-3 variant seen here was a long-range reconnaissance version, equipped with cameras in place of some armament, while still retaining impressive speed and defensive firepower. The Me-410 excelled in fast hit-and-run missions against unescorted bombers and in reconnaissance roles where its speed was a significant advantage.
However, the arrival of long-range Allied escort fighters like the P-51 Mustang exposed the Me-410's poor maneuverability, leading to heavy losses in daylight combat. By late 1944, the Me-410 was withdrawn from bomber destroyer roles but continued to serve in limited numbers as a night fighter and reconnaissance platform until the war's end.
Captured examples like this provided the RAF with valuable insights into German twin-engine fighter designs.
