rverissimo Posted July 17, 2025 Posted July 17, 2025 Art at scale 3D print 1:32 A6M Zero Bulkhead with seat in Botton position Code: 200-A32017 Price Tag: 17,24€ Introductions In recent days, I’ve been presenting several products from Art Scale Kit here on the forum. This brand has been expanding its range of aftermarket modelling accessories, and this product is a great example of how far 3D resin printing technology has come — allowing for the creation of almost anything we can imagine, with unmatched detail and at a lower cost compared to traditional resin sets. What’s in the (clear) box? A small cube containing two parts: the bulkhead and the seat. This set is designed to fit the 1:32 A6M Zero by Tamiya. At first glance, the finesse and detail are impressive. The seat frame and height adjustment system — composed of pulleys and cables that raise or lower the seat arms — are all finely printed. The lever that controls this movement is also well detailed, clearly showing how the mechanism works. As any 3D print, is possible to print in one space all parts and the protective parts. The resin cube, a by-product of the 3D printing process, includes support structures used during printing. Removing the parts from the block is quick and easy. I started by trimming the upper ends of the supports with side cutters, working my way down to the base, and then detached the bulkhead and seat from the block. Minimal residue remains, and a sharp blade is enough to clean it up. No visible print layers visible. the seat Dry Fit & Details The model can be dry-fitted, and the seat fits perfectly into the frame. The bulkhead is a refined replica of the original part, with added detail. It includes holes for attaching the oxygen bottles from the original kit and for fitting the cockpit side panels. Seatbelts are not included, so you’ll need to use those from the kit or an aftermarket alternative Conclusion This is a simple upgrade that significantly enhances the original Tamiya kit part. The 3D printing allows for fine detailing, and the price tag is another competitive advantage. As it replaces the original part, integration into the cockpit is straightforward. The seat also replaces the original with obvious improvements in fine detail and structure. Recommended! Many thanks to ASK for providing the review sample. Ricardo Veríssimo 3
