Hiya Folks,
                Another tank from my collection,.....here is the 17 pdr A30 Challenger, made from the SKP kit;
Here it is almost ready to start painting........quite a bit of filler needed but a simple build (on a Tea Tray lying on the settee whilst recovering from an injury) which I enjoyed as I`ve always liked the WW2 Chally!! The metal 17 pdr is superb but I`ve chickened out with the tracks however and although I was going to order a set of resin `Trak Pak`s' from Acc Armour a kind fellow modeller gave me a couple of sets of rubber Tamiya Cromwell tracks instead which did the job nicely, he used metal tracks on his models;
Here is the finished model;
It is meant to go on a diorama one day once I get better at doing this sort of stuff, hence the uneven tracks!
The colour scheme is based on photographic evidence which shows three or four A 30 Challengers of 7th Armoured Division wearing a disruptive camouflage finish seen amongst lines of Cromwells being prepared for battle, seen here;
Hope you like it,
                        Tony
Very nicely done. Camo is applied very well. Whose figure is that?. When you make your duo you can just glue the track down.
Cheers,.....I think that the figure is Ultracast,.....he was just sitting in my spares box so I painted him up! I actually wanted the track to be uneven so that I could show it going over uneven ground,......I intend to put some small pebbles under the tracks at the points where it is raised. I`ve left the wheels loose too so that they can be moved up or down too to replicate the suspension,
           Tony
