Thanks guy's. The undersides have been weathered. Using oils I've concentrated on the main panel lines building up gunk and grime deposits
Sealed under acrylic clear to protect it. Next in line are the wheels, spinner and prop blades.
Cheers Bevan
Hey Mike, the green/blue 76 is a custom mix.
Gunze H74 sky (duck egg green) 1ml
Tamiya XF2 flat white 12 drops
Tamiya XF12 jn grey 2 drops.
Thats the basic colour, I also used the h74 in random spots as well as the xf 12 all well thinned.
Hope this helps
Cheers Bevan
Were any of the other colors custom mixes? Excellent work!
Hi, yes the RLM 81 is a custom mix
Gunze H421 RLM 81 1ml
Tamiya xf9 Hull Red 4 drops
RLM 76
Tamiya xf23 1 ml
Tamiya xf 2 flat white 20 drops
This mix was used on the ailerons wing and tail plane tops. Bottom engine cowling was Gunze RLM76 out of the jar
Hope this helps
Cheers guy's.
The wheel hubs were painted with xf1 flat black and the tires with a mix of xf85 rubber black and xf2 flat white. I then sealed them with a coat of acrylic clear. Next I gave them a pin wash of Tamiya enamel xf 10 flat brown, sealed with clear. I sprayed a thin mix of black around where the tire meets the hub. I then thinned some xf24 dark grey with a drop of flat white and lightly tried to highlight the bulged part of the tire, again sealed with clear. With the xf10 flat brown and xf57 buff enamel I touched here and there for a bit of grubbiness followed by some white oil paint over the whole lot. 2b grey lead pencil was used on the edges for a bit off chipping.
This was all coated with Testors model master flat acrylic clear.
The prop blades were painted with Gunze RLM 70 black green and given a wash of white oil paint. Sealed with testors flat, the pencils came out for some scratches.
.............and I gotta say, pretty average shots of the props!
Cheers Bevan
  • 1 month later...
Hi guy's, been a while in between drinks.
The exhausts were painted h76 burnt iron with xf2 flat white added then matte coated. Burnt umber pastel dust was rubbed in and affixed with an xf85 rubber black enamel wash. Then matte coated again. A thicker application of the xf 85 wash was applied around the base of the stubs. 2b grey lead was touched along the edges of the openings and finally the openings themselves were blacked out.
Hope everyone had a great Christmas.
Cheers Bevan
Lovely build Bevan- just Lovely! You're a master of shades and mixes..
I must ask about your camera gear and set up- what are you using?
Ted
Ted
Hi Ted, thanks.
Nothing fancy about the setup just a fugifilm finepix j20 set on auto with the macro function on, flurecent light and a black background. A little editing as well!!
Cheers Bevan.
G-day Bevan, nice work mate, the vertical streaking in the exhaust stain is a nice touch.
Lovely scheme choice,
Cheers,
Bevan,
I really love this thread: Bump!
I hope I can manage half of what you did here!
Again, lovely work!
All the best
Ted
