Cool project. It's a very nicely detailed kit, although with some soft details here and there. Fit can also be challenging if you want to keep the raised surface detailing!
Thanks for the heads up Erik. I'm looking forward to the build.
Well of we go to F-106 Delta Dart land, lol!!
For an older kit the plastic seems pretty clear of flash and ejector pins marks. The plastic however is a bit thin and soft!
2A05D11D-C19D-4C33-AFF4-5D135FBE66AF_zps
For a 1/48 kit the cockpit has some wonderful detail.
D3AEB8C5-53B5-48E9-A19D-BDBF3CA87D64_zps
05E810A4-2C87-4EE4-87FA-B032CE730EFB_zps
The ejector seat detailed nicely but will be hard to see in the narrow cockpit!
CFA05581-200E-4869-A1E6-8C77DD56730C_zps
Pretty narrow but at least the chair shows!
45CE67A4-74D7-4D4C-89F8-95886030EC2C_zps
Fuselage is a good fit but the wings look tricky!!
2F28A244-1F3F-41A0-807C-490B7C455754_zps
Did a little dry fitting today before starting to mask the fuselage and inner wing section to be painted Tamiya zinc chromate. This model has great detail in the wheel wells and weopons bay however the plastic is reallt soft!!
C0ACC48A-D701-43EE-B8B6-ED227772EB86_zps
AB5EFF9C-F300-43A3-A595-358D8DD590BC_zps
Revell 1/48 F-106 Update.
So far so good but a bit fidgety! Lots of great gear and weapons bay parts with nice detail for sure.
C9B0AB3F-64D2-4A61-BDF2-EF1A5309AE71_zps
062C4C8F-293A-4920-9DBA-36666FD64150_zps
47819ECB-4733-48A2-AFF9-7B01940A27FA_zps
7CECEB46-C54B-4269-85DB-F5ECB977374B_zps
The paint shop crew sprayed all the newly install parts with a coat of white primer followed by a coat of zinc chromate.
Hopefully the engine shop will finish up the afterburner section for installation today allowing for the fuselage sections to be joined!
52929897-7E41-4837-8B7A-35324FFCB5CA_zps
5AD5F375-2DE5-4754-A8D4-22607D1596A0_zps
Well it's true what all the forums were saying about the intake fit being so bad but a few days of seam and gap work has solved that problem! A few touch ups, some sanding and I'll send it down to the paint shop guys, lol!!
8192A39C-04E7-4FF3-A608-B5E0BBB1F127_zps
874599C6-B434-472C-9EDE-8896DC73FCAA_zps
  • 4 weeks later...
Been a bit behind schedule on the F-106 due to the group tank build on "The Basement Air Force". We've been having great fun!!
Finally got the primer down and the panel lines highlighted.
2669B0D5-9259-407D-BB17-A7CB05ECA091_zps
Sweet looking F-106. Love the paint job on the ejection seat. I have the new Trumpeter 106 in the works. I always loved the century series a/c. Keep the awesome work up :)
Cheers Brian
Cheers Brian
Thanks Brian. So far this has been a great build although a bit cappy around the inlets and sides below the cockpit! I'm building this for a friend who was a crew cheif on the aircraft.
Nice work on filling/correcting those intakes!  I look forward to seeing this come together
Yea the seams on this Revell kit were challenging to say the least!!
Did a bit more work on the F-106 today!
Installed the belly fuel tanks and weapon bay doors,
22A5160C-BA50-493F-8CBE-A443C3EEF4A2_zps
Install the main and nose gear assembly and doors.
624AE0AA-08A2-4D51-97B0-09611EB398E1_zps
Ready for primer!
2D769002-7987-4952-8314-7403A01D3BEE_zps
Primed and sitting on it's own gear!
62D94C3B-EB54-4329-B244-EAE8380915F0_zps
Well let the primer coat dry/cure for a few days then spray the Gloss Light Grey base coat!!
Big weekend for the F-106!!
Semi-gloss gray base coat!
1DB50442-BCCF-4926-A654-CCD3C6445FBF_zps
Repainted the weapon and gear bays!
92104B2E-B076-4833-A2BF-FEB8667ABF78_zps
Maked and painted the nose and started decaling!
EB8B478F-6103-423E-983B-699F0C579177_zps
4EF25F4B-9FC3-40BF-9167-E0D1FFF6CB14_zps
E2032E9E-8E27-4D32-A213-765F8AAB6E31_zps
Installing the weapons!
740877E7-5533-4B9D-8B59-D6D2378623C6_zps
F5E4AAF4-8FA0-4B00-BD4A-1EEDD0CE4175_zps
Dry fitting the weapons.
2279DEF5-8BCB-4B1A-9191-3331C14E6DE8_zps
