Revell 1/28 Sopwith F.1 Camel
History
An agile, highly maneuverable biplane, the Sopwith Camel accounted for more aerial victories than any other Allied aircraft during World War I. Credited with destroying 1,294 enemy aircraft, it was called the Camel due to the humped fairing over its twin machine guns. Much like a real camel, this aircraft could turn and bite you. Noted for its tendency to kill inexperienced flyers, many pilots feared its vicious spin characteristics. Until sufficient speed was developed during takeoff, Camel pilots maintained full right rudder to counteract the torque the rotary engine. Failure to do so often resulted in a ground loop with the Camel crashing on its starboard wingtip. During World War I, 413 pilots died in combat and 385 pilots died from non-combat related causes while flying the Sopwith Camel.
The Kit
This is one of three newly reboxed models by Revell of its tried and true 1/28 scale originally manufactured in the early 1960's. The other two were the Fokker Triplane and Spad XIII. Several years ago they did a Fokker D.VII but much to the chagrin of modelers everywhere, it turned out to be a real dog mostly having to do with a very poorly manufactured upper wing.
Anyway, Baby Boomer modelers have built at least one of these three planes. They were fun because they were large and because they had cool box art! The kit itself has soldiered on rather well over the years. There are the usual problems with ejector pin marks in all the wrong places that will require some time to remove or fill.Thanks to its size, there is a pretty good amount of detail. Actually, WWI planes can be well detailed because there isn't that much in the way of lots of bits. The kit comes with a full rotary engine and a nice pilot figure to pose rakishly leaning against his plane. There is a removable access panel to look at the back of the engine.  Another nice option is that all the holes for rigging have been drilled out already. One only need to run the thread through them.
9DA71CC4-0404-4CFF-9F66-F2D5A5242925_zps
9B6F801D-66C4-4C58-8671-23781DD75020_zps
8CFC31EB-CE0D-4C73-B172-9D9F84C7A4A9_zps
D1920861-5942-4914-8B29-2C4E7CDC0B21_zps
The Instructions
The instructions are what I call Euro-instructions. That means no written information and only drawings. The 10 construction steps are more than adequate and they also show specifics on rigging the plane as one goes along.
48BC8BC3-69A5-4B08-B2ED-6691F22DB723_zps
91D9115F-E839-497C-A4D8-B1B111F917C3_zps
54744599-1124-49DC-AD9C-7D76E400F5AB_zps
0DAA1801-0B95-4223-B673-CA70DD26FE11_zps
496F9B9A-4F85-475C-BD55-56663D04B898_zps
65BC47B8-157C-4211-BA04-D2D7DDC19E1F_zps
Watch for the start of my Sopwith Camel build in a week or so :-)
Interesting subject Ralph! And very detailed thread as well, thanks for the history text :)
LOL yea I was going to post this, my first review, in the review section but could access that thread!!!
My goal is to be able to build a WingNut kit so I'm going to use the Revell Biplanes to hone my skills. I also have a 1/48 SE5A kit but its really small!!
Lets get started Ralph!  Interested in seeing it come together!
Just have to finish my Revell F-106 and I'll be ready to start!! Keep watching :-)
Okay here we go!! Ready to practice wood graining!!
Wood grain supplies!!!
178D7485-9B03-4CA8-A18D-07637A545103_zps
Priming and base coat for parts to be wood grained!!
953DAF5F-CAEF-4953-9D77-A08F45FF577D_zps
Wood Graining 101, lol!!
2DB8833D-83B7-4AE2-9B7C-D37608569256_zps
B0A3CEA0-2E0B-4A69-AE67-A04175B3F23D_zps
Continue on with my wood graining effort!
Very pleased with the prop!!
C72A14E8-4191-4EE2-AC33-AA9B24904394_zps
Primed the wings, higlighted stitching ribs and painted the upper and lower surfaces. Still haven't mastered staight lines with my airbruch, lol!!8DA47F4C-0E30-474C-B2C5-9A2292AAB91E_zps
Green upper wing surfaces.
F7489312-6407-420A-9BF2-40AB3548FB5E_zps
Tan lower wing surfaces.
52153020-73A6-43A1-979E-70BE4269D7B3_zps
And finally continued on my attempt to woodgrain and detail a WWI cockpit. Looks ok but I still need lots of practice, lol!! Oh and I need to take care of that injector pin mark on the left side headrest. Good Lord Revell!!!
743E9435-6BA3-45E0-84C8-69C07F1805F2_zps
Nice work Ralph in a very old model kit!! nice to try out new techniques.
Thanks Pardelhas for the kind comment.
I'm using this Revell Spowith and Spad kit to practice all the techniques needed to build my WingNut Fokker D.V11 (A1b).
So far I have really enjoyed learning how the simulate wood grain. Very cool process I must say!
Progress continues on the Sopwith!!
Working on the wood grain cockpit interior.
F49C6D8C-E5E3-457D-B9EA-9093EFCD98A7_zps
Cockpit. Really like the brass work!
F5E789D8-5D76-42F8-BC02-3937B57288F5_zps
Seam work!
32858A36-0857-4EE5-BC21-10D9981B7853_zps
Priming the fuselage.
C175CFD1-2786-4467-8A68-CFE5E2A6119C_zps
Dry fitting the engine and cowling.
B2323D98-2B15-4D0D-9266-3876CC48285B_zps
Finished the wood grain around the exterior of the cockpit, masked and painted the fuselage OD, set the engine and cowling and added the bottom wing and tail surfaces today!!
02C6AAF9-1F42-4A7E-A6CA-3AC885EDD157_zps
C2FE5D94-DBA1-44E7-B236-3FD6FE17FD6D_zps
Continued the Sopwith Camel by installing the machine guns.
C7C3F594-DC76-4484-96D4-BC0001C9EB0B_zps
A79E45F4-E068-485B-B63C-7908F0C25C7D_zps
Getting ready to install the upper wing.
7B0AA582-9A5E-4C3A-ADA0-8AC4E14EAAA7_zps
9DE622DD-E17E-41DD-9BE5-4E570F32F99D_zps
Two is better than one!
1DDAEBD6-DD7F-4840-B65B-1B467D155321_zps
Installing the main landing gear.
8E8AE025-A432-474B-B1B0-BB2356AFC925_zps
0487D137-4A6D-4387-8F70-92833E63D196_zps
Starting the rigging using .020 styrene rods.
893F622E-0949-4AB8-A44C-144CEF8490C3_zps
Painting the rigging!
8F5F30E8-89B4-43F8-AD15-6506D640332B_zps
F76B1527-69F4-4B49-BAFB-16995DD8DF46_zps
Painted each rigging wire end in Vallejo Brass to simulate turnbuckles and ready for decals!
571BB8FB-2349-40B8-A2E7-E367C38B3D1D_zps
See the finished kit in the completion thread!
