ajcmac Posted December 16, 2014 Posted December 16, 2014 By having little free space in my showcase I stopped building models in 1/32 scale. Yet here I have some one or two already started and some still sealed in the box. One, a P-40E Hasegawa, that I started to offer to a friend. The model that I intend to build is the «Texas Long Horn» This model looks like a patchwork quilt. The use of Hasegawa for with the same mold do the various versions of the P-40. Much putty and sandpaper. Redid lines and rivets. Finished interior. The seat with the seat belts. Regards ajcmac 3
RalphSarc Posted December 16, 2014 Posted December 16, 2014 Looking good! What aftermarket seatbelts did you use??
Administrators JeroenPeters Posted December 16, 2014 Administrators Posted December 16, 2014 That looks great! Nice depth in color. Keep it up!
ajcmac Posted December 17, 2014 Author Posted December 17, 2014 RalphSarc The metal parts are HGW and belts made with Tamiya tape. JeroenPeters Thank you. Continuing. As I had already said I used a lot of putty and a lot of sandpaper. Glued wings and fuselage. I started painting the Azure Blue. A mixture made with Tamiya paints. After I applied light and shadow. Regards ajcmac 2
ajcmac Posted December 17, 2014 Author Posted December 17, 2014 I had ordered the mask Eduard to continue to camouflage paint and this about a month. Still waiting. On the one hand it was good because it allowed me glue and paint parts that usually leave for the end and then it takes me a long time to finish the model. The propeller. Doors and landing gear. Painted the wells of the landing gear ... and finished the additional fuel tank. I am currently trying, with Tamiya tape, make the mask for the canopy. I hope to get to continue painting the model. Regards ajcmac 5
TeWika Posted December 17, 2014 Posted December 17, 2014 This is interesting! You have a very good eye for airbrushwork and shading. Cheers Ted
Daywalker Posted December 17, 2014 Posted December 17, 2014 Very impressive work, what Tamiya mix did you use for the azure blue? I like it.
ajcmac Posted December 17, 2014 Author Posted December 17, 2014 This is interesting! You have a very good eye for airbrushwork and shading. Cheers Ted Very impressive work, what Tamiya mix did you use for the azure blue? I like it. Thanks for following . Daywalker This is a mixture that appears in Beaufighter Tamiya 1/48 to Azure Blue. X-16 (3) + XF-2 (10) + XF-18 (5). Regards ajcmac 1
Daywalker Posted December 17, 2014 Posted December 17, 2014 Looking at the spinner, the OD color is so rich. Not quite sure how to explain it, but I really like the look you have achieved. Is it mostly pre shading that is very subtly showing through? What paint are you using for your OD? I have had mixed results getting "the look" with OD, but yours is just what I would like to achieve.
ajcmac Posted December 18, 2014 Author Posted December 18, 2014 Looking at the spinner, the OD color is so rich. Not quite sure how to explain it, but I really like the look you have achieved. Is it mostly pre shading that is very subtly showing through? What paint are you using for your OD? I have had mixed results getting "the look" with OD, but yours is just what I would like to achieve. Daywalker I use the post-shading. Then, shading, silver applied with a sponge and finally a wash with Wash Dark MIG. Regards ajcmac
ajcmac Posted December 19, 2014 Author Posted December 19, 2014 Thank Polux. After I know that the mask was out of stock I decided to make the mask for the canopy. Finally I will be able to continue with camouflage paint. Regards ajcmac
TeWika Posted December 19, 2014 Posted December 19, 2014 I'll Second Mr Polux- you got a besutiful thing going on here! I really enjoy watching you work, very inspiring indeed Merry Christmas Ted
TeWika Posted December 22, 2014 Posted December 22, 2014 How did you find the fuselage/lower wing and upper wing joint? (I had some weird fit issue) Ted
ajcmac Posted December 22, 2014 Author Posted December 22, 2014 Thanks for the kind comments . Tidy work! Looks very well!! I'll Second Mr Polux- you got a besutiful thing going on here!I really enjoy watching you work, very inspiring indeedMerry ChristmasTed How did you find the fuselage/lower wing and upper wing joint? (I had some weird fit issue)Ted Ted Overall, wings, the rear of the cockpit, the rear fuselage, the fittings are weak. I used a lot of putty and sandpaper. On the wings solved the problem by using a bit of sprue. To all, Merry Christmas. Regards ajcmac
ajcmac Posted December 23, 2014 Author Posted December 23, 2014 I painted the Dark Hearth. I used the H-72 of Gunze. For vertical stems used the same paint (H-72) and painted at the same time. 2
TeWika Posted December 23, 2014 Posted December 23, 2014 You're making good progress! Is Gunze your preference when airbrushing? Ted
ajcmac Posted December 28, 2014 Author Posted December 28, 2014 You're making good progress! Is Gunze your preference when airbrushing? Ted Ted Sorry about my English. I hope you understand. Since I can remember I always used Tamiya paints. First the enamel and then acrylic. As before was building tanks never had problems. Since I switched tanks for aircraft models (2009) emerged me problems since the Tamiya had no specific paints for model planes. Much searching on the net and a lot of trial there could go arranging mixtures. Fortunately, with the launch of models in 1/32 scale things were improving. Earlier this year I built a model from Tamiya... Dornier 335 with RLM 81 and 83. The references by Tamiya, as was becoming habit, always referred up the cans of spray. I do not like and the mixtures I did also not please me. Then moved to the Gunze. I've used and liked. For dilution use thinner Tamiya (X-20 A) and do mixtures, lights and shadows, with white or yellow and black Tamiya. Despite continuing with the Tamiya paints in aircraft models English and Japanese on Germans models I started to paint them with Gunze. Regards ajcmac 2
TeWika Posted December 28, 2014 Posted December 28, 2014 Ajcmac, I understand your English- no problem:) I like your Pfiel- well done! I agree with you about Gunze for Luftwaffe is the best solution and also tamiya thinner ( works very good) What kind of airbrush you use? Regards Ted
ajcmac Posted January 1, 2015 Author Posted January 1, 2015 Ajcmac, I understand your English- no problem:) I like your Pfiel- well done! I agree with you about Gunze for Luftwaffe is the best solution and also tamiya thinner ( works very good) What kind of airbrush you use? Regards Ted Ted I use Harder & Steenbeck Evolution. More putty and sandpaper. It Seems to have no end. The Dark Earth applied completed before the end of the year. At this time already have Dark Green ready. I am waiting for everything to dry in order to remove the mask. Wishes to all for a Happy New Year 2015. Regards ajcmac 2
TeWika Posted January 1, 2015 Posted January 1, 2015 Ajcmac, She looks great- I love the filter shade.. very sandbeaten and sunbleeched I wish you a super 2015 All the best Ted
ajcmac Posted January 2, 2015 Author Posted January 2, 2015 Thank TeWika. Mask removed . Regards ajcmac 2
ajcmac Posted January 4, 2015 Author Posted January 4, 2015 Chipping and then gloss clear. Ready for placing decals. Regards ajcmac 2
