rkranias Posted April 26, 2017 Posted April 26, 2017 I've always used Florys wash and I will be using MPLW overall on an aircraft build for the first time. Big Question On Surface Prep: An acrylic gloss is recommended to prepare surface for MPLW. What do you all use? I'm thinking on using Tamiya Clear thinned with Gunze Leveling Thinner. Using Gunze Leveling Thinner a bad idea? I used MRP overall and the finish is a nice sheen MPLW works fine on MRP surface. However, should I protect the decals with acrylic gloss? Any coaching will be appreciated. Thanks - Rick
GusMac Posted April 26, 2017 Posted April 26, 2017 Hi Rick, I've used the panel line washes on my last couple of builds and they're great with a good range of colours. I used Tamiya and Gunze colours but on both occasions sealed things with a gloss coat before use. I find Doogs' technique for this very good - a coat of lightly thinned Tamiya clear then immediately a misting with Mr Levelling thinner. Gives a great finish. Have no experience with MRP, but I have used the MPLWs straight over Tamiya gloss acrylics in the gear bays and it worked well. If the MRP gives a decent sheen then you'll probably be okay.
