Airbrush Painting Clips Holder
HobbyZone
Catalogue # HZ-AC1
Available from HobbyZonefor £13.54 (at current rates)
DSC09362.thumb.JPG.875de65928314b807d0df
Modellers tend to be quite resourceful and innovative folks, from scratch-building parts, to fabricating things to make their hobby a little easier. One such fabrication, for me, is a polystyrene foam block with cocktail sticks to hold parts whilst I airbrush them. I also stick parts to steel rules that have been covered in masking tape, plus I’m always using bits of Blue-Tack to mount parts to whilst I paint. It just seems to be the way I’ve always worked. Doubtless, you do the same, or have your own bespoke solution. HobbyZone have quite a nice solution to this that you may just be interested in.
DSC09363.thumb.JPG.67ab4a04172fc70994173
I’ve actually been sitting on this review for a couple of months now, pending the release of this new product from HobbyZone. Today, they asked me to publish it for you. The concept is very simple. It’s essentially a magnetic box with a series of holes in the lid. Into these will fit stiff wires that are furnished with a shrouded crocodile clip on one end. You pop your model part into the jaws and then paint. Whilst drying, you can stand the wire upright in the lid. After your work, all the wires sit neatly in the box, out of the way.
DSC09364.thumb.JPG.7d1ca78c1842e28cbce85
DSC09365.thumb.JPG.172ef06709773b09c008a
This product, like all those from HobbyZone, are machine cut from MDF, and require assembly. This one is packed into a sturdy corrugated box with a simple product label. Upon opening the box, you’ll note that all parts are protected with a covering of bubble-wrap. Upon removing that, you’ll note that the box itself is built up from five layers of MDF. These form the base with a white plastic outside coating, and two frame parts, one of which glues to the base, and another recessed frame which glues to the top of this. The two-part lid then sits in this and is held via magnets.
DSC09369.thumb.JPG.9e2be0bd05f31af996a4b
DSC09366.thumb.JPG.0087a0b96949fe845967c
DSC09367.thumb.JPG.2026ca8faa656b1f29d6c
DSC09368.thumb.JPG.ecdbb96bc98b9baf86dc2
To complete the package, a series of nine neodymium (rare earth) magnets are included, as are nine croc-clip wires and a set of instructions. The instructions are nice and simple to follow and I had no issue with understanding them at all, but for the ease of explaining this product to you, I’ve built this up as a guide for you. Here we go!
1.I start with the lid. Using TiteBond adhesive, I run a line of this around the non-recessed face of this part, and add some spots between the holes, being careful not to put too much glue there, or get too close to the holes.
DSC09379.thumb.JPG.660a24b35d77c43c75324
2.The white, plastic-coated lid is now fitted to the previous part and held with clamps until fully cured.
DSC09380.thumb.JPG.2d4336f138d3505b86f75
3.The base is now clued to the lower frame section (the one without the holes) and clamped until fully set.
DSC09381.thumb.JPG.59f38919a49f89957dda7
4.Now we can glue the upper frame in situ, being careful of alignment. Again, clamps hold this until filly set. Note the frames are slightly scalloped on each of the long edges. This is to give your fingers something to hold whilst you remove the lid.
DSC09382.thumb.JPG.9b96b8421152b848184d6
5.Now, this part is VERYimportant. We need to ensure that the magnets all fit into the holes, so the same pole is facing upwards on each one. This is dead easy. Keeping the stack of magnets upright, and keeping the same orientation, remove two of them and push into the one of the corner holes. Do the same with the others, again, without changing the orientation of your stack of magnets. These push in quite easy, but you know they won’t come out afterwards!
DSC09387.thumb.JPG.06a562c279d1be7259371
Now fit the lid to the box so that the magnets align with the holes in the lid. Push firmly down, and if necessary, gently tap the lid into place with a small hammer, being careful to protect the surface of the product. That’s it! The lid will now come off with magnets and will reattach in the same way. Job complete!
DSC09388.thumb.JPG.014f7bdd72b095e9b0cbd
6.After your work, store the wires/clips in the box and replace the lid. There’s plenty of room in there for more, in case you want to make your own clip holders.
DSC09389.thumb.JPG.f8a68ab7207a2ac551ac0
Conclusion
A superbly simple idea, carried off very nicely. As with all of HobbyZone’s products, this is designed to keep your workbench in tidy order, and of course, this has the functionality added to it. I’m quite a fan of HobbyZone, with my workshop being fitted out with all of their various storage modules, so I’m more than happy to stay true to the brand and its style/quality, with this addition.
My sincere thanks to HobbyZonefor the review sample seen here. To purchase directly, click the link at the top of the article.
hzlogo.png.7318d958e62876b9def558c326373
Me 2 :)
As for Hobbyzone stuff, yes it does definitely help keep a tidy workbench, for the price of a HK B-17, for a « full-meal deal »
