Hello All,
There was thread or two discussing how to do brass with paint. Someone, I forget who, had used clear yellow over aluminum and it looked awesome. So I tried an experiment and mixed up some Aluminum paint with some clear yellow and this is what I got.
1 part Tamiya Flat Aluminum
1 part Tamiya Clear Yellow
a couple of drops of Clear Orange to taste.
I'm calling out the brand only because I have no idea how other shades will work and this sis all I had.
This is the fuel and oil tank on my Fokker DVII I just started.
I suppose it could be a little darker but I made up a small bottle and will use it until I find a better one. I might try adding a little copper to see what happens.
Paul
I mentioned it a while back Paul, it was done by our very own member Pfuf on a build I saw of his elsewhere. I reckon if you asked him, he would be able to give you the recipe.
This is his build on which I saw it:
ce743bf1-5652-4401-a5ab-79baa7bfc5b5_zps
Hi I first use chrome alclad and then spray it with Tamiya clear Yellow I do mix some clear Red in it to get a bit warmer glow finish it with clear lacker very small parts I paint them using a brush.
Johan
Thank you Johan ... I've given you extra work, sorry, but I was so impressed with your method that I just had to point it out to others.
Johan
http://i1183.photobucket.com/albums/x476/Pfuf_Stuff/Bristol%20F6b%20Wingnut%20Wings/DSC07037.jpg
Other than with Tamiya-paints there'll be no visible metallic particles, so it's a great technique!
I suppose one could use Alclad Pale Gold straight from the bottle too for brass?
I used Tamiya X-31 "Titanium Gold"  for the WNW Albatros DV fuel tank.
And Mr. Metal color No.:219 "brass" for the fuel tank's on the WNW Hansa Brandenburg W29
I think,  -- in my eyes -- the Mr. Metal Color - "brass" is the perfect reproduction of the real "Brass".
Servus
Bertl
Here the Brandenburg tank without the "outside messing around".
Only Mr. Metal color "brass" (except for the two straps of course) and a little weathering with Tamiya "Smoke", -- that's all.
Servus
Bertl
